Do Other People Test Gcode by Hovering?
04 Jul 2018 03:18 #113370 by BrendaEM
Do Other People Test Gcode by Hovering? was created by BrendaEM
On my router-mill, I found it was handy to touch off in mid air and let the Gcode run.
Does anyone else do this?
Is it worth adding a UI button on an interface to disable the spindle motor?
-- BrendaEM
  • Moderator
  • Moderator
04 Jul 2018 06:07 #113388 by tommylight
Replied by tommylight on topic Do Other People Test Gcode by Hovering?
-- BrendaEM
Nope, i just browse through gcode and do the moves in my head so nobody can see or hear when i crash the machine ! :)
The following user(s) said Thank You: BrendaEM
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
04 Jul 2018 08:39 #113400 by ozzyrob
Replied by ozzyrob on topic Do Other People Test Gcode by Hovering?
To avoid crashes leave out the lines that do Bad Things. ;)
07 Jul 2018 18:12 #113699 by andypugh
Replied by andypugh on topic Do Other People Test Gcode by Hovering?
Yes, this is typically called "cutting air"
Moderators: piasdom
