Future retrofit project for Mesa boards
- kb8wmc
- Thank you received: 4
23 Aug 2018 20:13 #116501
by kb8wmc
Future retrofit project for Mesa boards was created by kb8wmc
I am looking at a future project of retrofitting an older cnc mill...The machine is a CNCExpress mill, serial number 00012...The mill comes out of an aviation tech school and was one of three identical machines...The mill shows only little wear/usage...There are no controllers and drivers...I can't imagine where they went...
Details: Spindle Motor is a Marathon Electric; 115/230V single phase 2HP; 1725 RPM, Model No. 7VA56B17F5548B P; FLA 18.8/9.4...
X and Y axes motors are MicroKinetics 34M470; 470 oz/in; 2.5v 5.9A; 42 Ohm...
I am looking for guidance and suggestions selecting appropriate a Mesa electronics package and suggestions for size and types of drivers...
The spindle motor works but I am uncertain about the MicroKinetics motors, so I may need to replace them...
Any input will be appreciated...
Thanks in advance.
Mike
Thanks in advance.
Mike
- Thank you received: 7478
23 Aug 2018 21:05 #116503
Those look like stepper motors so there is a wide choice of drives, from Chinese to Lam Technologies that i use very often as they have proven indestructible and configurable for almost anything.
As for mesa, there is the 7i96 or 7i76E or even a combo of 5i25 or 6i25 with 7i76.
Replied by tommylight on topic Future retrofit project for Mesa boards
Something wrong there, should be 0.42 Ohm or???
The following user(s) said Thank You: kb8wmc
Moderators: piasdom
Time to create page: 0.121 seconds
