FADAL RETROFIT ATC
  • COlger81
  • COlger81's Avatar Topic Author
  • Elite Member
  • Elite Member
22 Oct 2018 20:37 #119219 by COlger81
FADAL RETROFIT ATC was created by COlger81
What would the best approach be to programming the geneva ATC on my FADAL? The machine is up and running with manual tool changes currently. I have added 4.7k pullups to the hall sensors and the inputs respond great. I am currently working on the code in python but it seems that some basic python commands do not work. Any help would be appreciated. I attached the python script
that i have written so far.
23 Oct 2018 15:36 #119266 by andypugh
Replied by andypugh on topic FADAL RETROFIT ATC
I would suggest the "carousel" HAL component as at least part of the answer.
The following user(s) said Thank You: vmihalca
23 Feb 2019 11:52 #127000 by pl7i92
Replied by pl7i92 on topic FADAL RETROFIT ATC
you may show a Image of the ATC
to get some more information
but as Andy sugested it is most likly to use the Carousell.comp to get ahed working ATC
Moderators: piasdom
Time to create page: 0.307 seconds
