Pedersen VP2000 810M retrofit, severe servo hunting
- Juckix
- Topic Author
The original system never showed any significant hunting (not noticeable). I suspect it might have disabled individual axes after reaching the set point, but it seems that all the analog enable signals only show up as a single pin in HAL. This is just speculation though. Thoughts?
- Thank you received: 5332
Z axis are often harder to tune because they typically have a static load
- Juckix
- Topic Author
- Juckix
- Topic Author
- Juckix
- Topic Author
- jmelson
- Thank you received: 126
This adds a steady force in the servo to counter the head's weight.
Jon
loop in the drive itself (to counteract gravity) if this is possible.
- jmelson
Yes, if this is available in the drive, and IF the pots can be set fine enough for this, then that is quite right.PCW wrote: If these are velocity mode drives, its actually better to add some offset to the torque
But, some servo amps just have one-turn pots, and you can't get anywhere near fine enough adjustment.
Jon
