Mitsubishi servos
- Leon82
- Thank you received: 79
09 Sep 2019 23:16 #144634
by Leon82
Mitsubishi servos was created by Leon82
What is the strength of this servo. Are the torque ratings different from a stepper motor?
Mitsubishi HC-KFS053D 50W
Here is a link for some specs
shop.bertelkamp.com/products/HC-KFS053D
It says .12 ft pounds. How does that compare to a 540 inch oz stepper? Is there a different size standard for servos
Thanks.
Thanks.
- Thank you received: 5326
10 Sep 2019 01:12 #144639
Replied by PCW on topic Mitsubishi servos
Well 0.12 ft lbs is 23 inch oz's so it continuous torque rating or the servo is less
the 5% of the 540 oz/inc stepper
Note that the servo may have a peak torque of 100 inch oz or so but only for a few seconds. (This is not really unexpected since a 50W servo is _very_ small)
The following user(s) said Thank You: Leon82
- Leon82
10 Sep 2019 02:31 #144652
by Leon82
Ok, thanks. I figured that would be the case, just wanted a little sanity check.
Its not going to work for what I want.
Replied by Leon82 on topic Mitsubishi servos
Moderators: piasdom
Time to create page: 0.470 seconds
