Ballscrew dustcover recommendation
- Louis Cypher
07 Oct 2019 16:52 #147351
by Louis Cypher
Ballscrew dustcover recommendation was created by Louis Cypher
Dear Forum,
I have a gantry type 3 axis milling machine. Since I will machine a lot of foam I want to protect the ballscrews from dust and chips. Can you point me to good solutions to do so? I was thinking of a bellow type cover.
Thanks in advance,
Louis
Thanks in advance,
Louis
- piasdom
- User is blocked
- Thank you received: 9
07 Oct 2019 16:58 #147352
by piasdom
Replied by piasdom on topic Ballscrew dustcover recommendation
the bellow is probably the best way i think. i have two that i'm not using you can have.
not sure how to give address here, but you're welcome to them.
- Louis Cypher
07 Oct 2019 17:55 #147357
by Louis Cypher
Replied by Louis Cypher on topic Ballscrew dustcover recommendation
That sounds great! I'll try to send a private message
- piasdom
- User is blocked
07 Oct 2019 17:57 #147358
by piasdom
good luck
cause i don't know how here
- BigJohnT
- Thank you received: 994
07 Oct 2019 23:33 #147388
by BigJohnT
Replied by BigJohnT on topic Ballscrew dustcover recommendation
Private Messages (PM) is not possible on the forum.
JT
JT
- piasdom
- User is blocked
08 Oct 2019 00:52 #147400
by piasdom
Thanks John
- Louis Cypher
08 Oct 2019 08:54 #147441
by Louis Cypher
If you are on RepRap Forum or Thingiverse: I have the same User Name in both of them
- pl7i92
- Thank you received: 358
08 Oct 2019 11:01 - 08 Oct 2019 11:05 #147445
by pl7i92
Replied by pl7i92 on topic Ballscrew dustcover recommendation
make your own one
svenhb.bplaced.net/?CNC___Fraese_3___Faltenbalg
search for FALTENBALK on Goo... or YT
Last edit: 08 Oct 2019 11:05 by pl7i92. Reason: info
- Louis Cypher
08 Oct 2019 11:26 - 08 Oct 2019 11:40 #147448
by Louis Cypher
Cool, that's what I will do! The paper version should be easy to produce on a laser cutter. Anybody here knows a source for Tyvek paper?
Found some. No need to search
Last edit: 08 Oct 2019 11:40 by Louis Cypher. Reason: Added more information
- piasdom
- User is blocked
08 Oct 2019 11:40 #147450
by piasdom
or thingverse, i found the message area.
The following user(s) said Thank You: Louis Cypher
Moderators: piasdom
Time to create page: 0.105 seconds
