Kitamura Mycenter 0 ATC ARM Help
6 years 8 months ago #156791 by drimaropoylos
I also thing that the CW and CCW in lines S56A and S61A they control the spindle and not the arm.
6 years 8 months ago #156816 by DaOne
John, watch my slow motion videos. The CW or CCW is just the motor direction. The cam controls the actual movement directions. The only difference I see is the sensor timing and the direction the arm moves when it is down swapping the tool. It looks like it will work either direction but in CCW mode it matched the video of someone else's machine.
6 years 8 months ago #156855 by drimaropoylos
So there is a cam system like in the photo and all the moves are made from one motor?
6 years 8 months ago #156896 by DaOne
Yes
6 years 8 months ago #156897 by DaOne
And the motor is controlled by a mini vfd
6 years 2 months ago - 6 years 2 months ago #177413 by mclausen
I don't know if you have this solved yet, but I have Mycenter 1 (probably older than yours), and the ATC arm motor is only controlled by a contactor. It can only go one speed and one direction.
Last edit: 6 years 2 months ago by mclausen.
