Definitely check the torque curve on whatever motor you want to use, DMM or otherwise. Also: inertia mismatch between the spindle and motor is a thing. I think I ran into that when I initially tried to use a smaller motor, but hard to tell amongst my other tuning issues.
I've got the 1 KW 86mm motor (86M-DHT-A6MK1) on my baby BT30 machine (~14x8x10 XYZ travels and ~500 lbs, IIRC). It's geared ~1:1.5 (motor:spindle), so I can go up to ~7500 RPM at the spindle. After finally getting the tuning right (see below), I'm still finding where the limits actually are, but:
Aluminum: Have gone up to ~3 cubic inches/minute, with 1/4" and 3/8" tools. Haven't had issues.
Mild steel: No issues. I don't remember hard numbers for anything aside from drilling a couple holes in 1018 steel with a 6mm carbide drill. 5000 RPM, ~20 IPM, no problem.
Stainless: I've cut 304 and 17-4 H925. Both cut without issue. I don't remember MRRs for either.
Hardened steel: I modified a screwless vise body, which is probably ~60HRC. Mix of 1/4 and 3/8 tools IIRC, cut fine, albeit with light cuts.
All of the cutting I've done has been within the motor's "continuous" operation power range, per HSMAdvisor (well worth the price, IMO). Just about all of my non-finishing operations are HSM toolpaths, so I can't really comment on slotting.
This may also be of interest for tuning a DMM DYN4:
www.forum.linuxcnc.org/38-general-linuxc...dle-servo-tuning-tip
