Retrofitting Mikron WF41C: Distance coded homing success
5 years 5 months ago - 5 years 5 months ago #208612 by cscegypt
Replied by cscegypt on topic Retrofitting Mikron WF41C
Hi Mark,
Many thanks for your efforts and valuable information. I enjoyed while reading your research and eager to know the results.
You can download the service manual for the TNC 355 via this link , maybe it can help :
www.yumpu.com/en/document/view/18882606/...issioning-heidenhain
Also there are other links for schematics of TNC 355 and also operator manual for mechanical part of the Mikron WF 41 CH
you can retrieve and download it in this website :
www.practicalmachinist.com/vb/deckel-mah...-wf41-c-mill-332906/
here is also the link for electro document of WF41to be downloaded.
drive.google.com/file/d/163tkgEy81i2cP-Rte4XLYW-Tc6Ng5uFe/view
also the schematics of 355 input board:
drive.google.com/file/d/1yUM2iP0Qc3McEn9BFEfq-942jTDPIbTB/view
I hope that you can repair the machine sooner .
Big thank you .
Heggy
Last edit: 5 years 5 months ago by cscegypt.
5 years 5 months ago #208916 by mwinterm
Replied by mwinterm on topic Retrofitting Mikron WF41C
Hello Heggy,
thank you very much. I already had all the documents in paper form but not electronically. This is very handy!
Regards,
Marc
The following user(s) said Thank You: cscegypt
5 years 5 months ago #208918 by mwinterm
Hello,
We finally started the next step of our retrofit journey which is implementing distance coded homing. I already outlined in earlier posts how I modified the code of LinuxCNC to support it but didn't try it out until very recently.
When trying it out I encountered the following problem:
When I initiate homing the machines starts moving as supposed to. When hitting the first index mark the encoder automatically resets the
hm2_7i92.0.encoder.01.position
This leads to a miss-match between the commanded position and the actual position and results in a jerky move to actually re-establish a match between the two and eventually in a following error.
Not sure how to really solve this problem. I have two approaches in mind:
1. Not setting
hm2_7i92.0.encoder.01.index-enable True
during the index-mark search and instead listening to the
hm2_7i92.0.encoder.01.input-index
pin and try to capture the corresponding encoder raw-position. But if I do my math right I would have to move very slowley (<1mm/sec) to reliably grab the index position.
2. Extending Hostmot2 by a mode that would not reset the encoder when an index-mark is hit but rather write the corresponding position to an output pin.
Any help or suggestions greatly appreciated...
Best regards,
Marc
5 years 5 months ago - 5 years 5 months ago #208925 by cscegypt
Hi Marc,
I just read this paragraph in page 47 of the following link which is belong to Rockwell automation
literature.rockwellautomation.com/idc/gr...tion-rm003_-en-p.pdf
(Since the homing procedure usually requires the machine to be taken
offline and placed in a manual operating mode, for example, not making
product, anything that would require you to rehome one or more axes
on the machine is undesirable. This is downtime and costs money. The
APR feature maintains the machine reference or absolute position
through power cycles, program downloads, and even firmware updates)
Also , I searched Bosch website and found that link:
dc-us.resource.bosch.com/media/us/produc.../USL00010_2015-1.pdf
I wish that will introduce help.
Good luck.
Heggy
5 years 5 months ago #209006 by andypugh
mwinterm wrote: When I initiate homing the machines starts moving as supposed to. When hitting the first index mark the encoder automatically resets the
This was why I was suggesting an intermediate HAL component that would pass through a modified version of the encoder position.
5 years 5 months ago #209052 by mwinterm
Hello Andy,
while I don't dismiss a separate HAL-component (I just tested the modified home procedure first as I already implemented it) I don't understand how it would help with my current problem. When an index is found the encoder would still reset while the machine being in motion. Unless I would within the HAL-component try to capture the event of the reset instantaneously and artificially generate a 'fake' position signal consistent with the one before the reset (something I would not consider to be very elegant) I still would experience the same behavior. Maybe I'm missing something here....
However in the meantime I have modified the Hostmot2. I added a flag
hm2_7i92.0.encoder.01.reset-on-index
which is set to 1 by default to be consistent with the original implementation. Further I added an output parameter
hm2_7i92.0.encoder.01.index-rawcounts
I basically modified the following code in encoder.c (look for *** in the comment)
if (0 == (latch_ctrl & HM2_ENCODER_LATCH_ON_INDEX)) { // hm2 reports index event occurred rtapi_u16 latched_count; latched_count = (latch_ctrl >> 16) & 0xffff; reg_count_diff = (rtapi_s32)latched_count - (rtapi_s32)e->prev_reg_count; if (reg_count_diff > 32768) reg_count_diff -= 65536; if (reg_count_diff < -32768) reg_count_diff += 65536; //***Added if-statement to reset the offset only when hal.pin.reset_on_index is true (default) if(*e->hal.pin.reset_on_index){ e->zero_offset = prev_rawcounts + reg_count_diff; } //***Additionally always setting the rawcounts of the last index-position to pin.index_rawcounts *e->hal.pin.index_rawcounts = prev_rawcounts; *e->hal.pin.index_enable = 0; }
The
if(*e->hal.pin.reset_on_index){ ... }
causes the count and position not to be modfied if
is 0.
The
is always set to rawcounts value corresponding to the last index signal encountered.
Like that I was able to have the first successful distance-coded homing routines executed which delivered what seemed to be reasonable results :)
However some more testing and detailed verifying is still needed.
Best regards,
Marc
Time to create page: 0.439 seconds
