Servo Purchase Recommendations, Yaskawa?
4 years 11 months ago #227537 by ihavenofish
Replied by ihavenofish on topic Servo Purchase Recommendations, Yaskawa?
The encoder feed back is on the motor on my machines as well, and the delayed and oscillating motion of the table was still picked up by the encoders and looked like reversals from out of tune servos as well.
I understand that you say you didn't have the problem with the old control, but the very brief video you showed also appeared to have much slower motion than the clip showing the problems (and there is no way to compare acceleration settings from the video.)  If you've increased the speeds (max velocity and or accelerations) from the old system It wouldn't be surprising that you would have these kind of problems.
Also are you using velocity commands to the drives or torque?  I think a single PID loop torque command system looses the advantage of using feed forwards for tuning the PID in Linuxcnc.  (I am of the opinion that is a significant disadvantage and would make fast changes in velocity a problem.)
"The encoder feed back is on the motor on my machines as well, and the delayed and oscillating motion of the table was still picked up by the encoders and looked like reversals from out of tune servos as well."
no looks like, IS. its on the scope. as i said, and every speed and every acceleration. all the identical behavior. 0.01G and 1ipm, same reversal and "bang" or resonance. 0.5G and 700ipm, exact same bang, exact same scope plot.
"I understand that you say you didn't have the problem with the old control, but the very brief video you showed also appeared to have much slower motion than the clip showing the problems (and there is no way to compare acceleration settings from the video.)  If you've increased the speeds (max velocity and or accelerations) from the old system It wouldn't be surprising that you would have these kind of problems. "
not even close. the clip of the adaptive clearing is 400ipm programmed rate (so, between 200 and 400 real speed). on the original control it is 787 ipm (the max speed of the machine). acceleration isn't explicitly stated in the old control, but the manual suggests it is 0.5G (100ms to 4000rpm or similar, i don't remember the number), which is what i set linuxcnc to although as above, i tried accelerations down to 0.001g and up to 1g and nothing changes at all.
"Also are you using velocity commands to the drives or torque?  I think a single PID loop torque command system looses the advantage of using feed forwards for tuning the PID in Linuxcnc.  (I am of the opinion that is a significant disadvantage and would make fast changes in velocity a problem.)"
velocity mode.
4 years 11 months ago #227538 by ihavenofish
in any case, how did you fix the motion?
4 years 11 months ago #227902 by Todd Zuercher
Replied by Todd Zuercher on topic Servo Purchase Recommendations, Yaskawa?
Once the mechanical issues were fixed the problems went away for me.  (Sent the worn ballscrews out to get rebuilt on 2 machines, replaced bad bearings in the rack and pinion drivetrain on two others.)
I've never experienced these kind of problems on any of the Linuxcnc machines I've worked with.  The above machines with the mechanical issues are all Fanuc controlled machines that worked well when new, but developed vibration issues as things wore out.  I've set up two servo driven machines with Linuxcnc (besides several stepper motor ones.)  One is running analog command signals using torque mode (those servos didn't support velocity commands), the other is using step/dir commands with encoder feedback and the position loop closed in Linuxcnc (behaves more like an ordinary velocity command servo.)
Maybe you should try setting up a dial indicator as you would to measure backlash, then push on the table either by hand or with a pry-bar or something, and compare the deflection measurement of the dial indicator with that measured by the encoder in Linuxcnc.  I'm sure this was all gone over in your tuning thread, but have you tried checking if there are any filter settings in the drive that should be turned off or adjusted?  Have you tried changing your drives to torque commands?  Some people have better results with that, when their drives are giving them delay issues with velocity commands similar to what you're seeing.  Have you checked to make sure the motors move at a constant velocity when a constant voltage is commanded and with a linear response? (ie Does a 0.5v command move half as fast as a 1.0v command?)
I've never tuned Yaskawa servos, myself but I do have a machine running them that I'm considering a Linuxcnc retrofit on. (The old control hasn't quite made me mad enough yet.)
4 years 11 months ago #227961 by ihavenofish
so, basically, you haven't used linuxcnc analogue velocity control.
could have cleared that up first.
4 years 11 months ago #228006 by Todd Zuercher
Yes and no, To Linuxcnc my step/dir system looks and behaves the same as an analog set up. Linuxcnc is still sending the exact same velocity commands to the Mesa card in exactly the same way as in an analog system. The only difference is in the Mesa card, it uses those velocity signals to create step/dir pulses instead of analog voltages, when the PID tuning is not correct it over or under shoots and will oscillate exactly the same as an analog system. The only difference is that I have to tune the position loops in both the servo drive and Linuxcnc. I was having a great deal of difficulty getting a good tune of the step/dir servos before adding the encoder feedback to Linuxcnc. Adding the encoder feedback and closing the position loop in Linuxcnc gave me 3 things, 1st it let me use Halscope for tuning (vs an ancient analog scope that barely worked) for tuning the servo drive, 2nd let me tune the drive's position loop a little softer for smoother motion and 3rd let me take better advantage of the feed-forwards in Linuxcnc's pid loop.
And for my torque command machine, I am using double pid loops, with the first sending what would be the analog velocity command to the 2nd that creates the analog torque command to the drive. It is PC(Linuxcnc => position PID => velocity PID) => Servo(motor), instead of the usual PC(Linuxcnc => position PID) => Servo(velocity PID => motor) I simply moved the velocity loop from the drive to the PC software, the main disadvantage being limited by the base thread speed where if the velocity loop is in the drive it is usually either analog and not subject to thread speed limitations or if digital running much much faster than is possible in Linuxcnc's thread system.
So Yes I'm using Linuxcnc's velocity commands, but no I'm not explicitly sending an "analog velocity command" to a drive.
4 years 11 months ago #228027 by ihavenofish
interesting on the pulse with encoder feedback. not a common scenario. what servos and drives are you running?
im trying to find a common denominator here - and its NOT mechanical. we went through that in my thread over 40 pages of posts. when the same behavior exhibits at 0.1g acceleration and 1ipm and 700ipm and 1g, its not the 0.0003" backlash, or springiness (which is has none), or anything else, its strictly between the drive and the control.
its hard to recommend anyone else a system when there aren't any direct examples of it working.
Time to create page: 2.385 seconds
