Alternatives to 7i76
4 years 11 months ago #227131 by cadpete
Replied by cadpete on topic Alternatives to 7i76
Great find Tommy. Was looking for the E version not ED. What would I need to change to use ED? Sorry for the newbie question but the design / help all generally seem to be for the E version
4 years 11 months ago #227132 by tommylight
Replied by tommylight on topic Alternatives to 7i76
48 points of isolated field I/O are provided for general control use including limit switch and control panel inputs, coolant enable and tool changer control outputs. Isolated I/O includes 32 sinking inputs and 16 sourcing (7I76E) or sinking (7I76ED) outputs. Inputs can sense 5V to 32V signals and the outputs can switch 5V through 32V signals. Maximum output load is 350 mA. Outputs are short circuit protected.
It has sinking outputs instead of sourcing ones on 7i76E.
sourcing outputs = the outputs provide +VCC when on, so the relays/solenoids/LED's have a common ground and the Mesa outputs provide the positive voltage when turned on.
sinking outputs = the outputs sink to ground level when on, so the relays/solenoids/LED's have a common +VCC (12 or 24V positive) and the mesa outputs provide GND/ground/0V when on.
The following user(s) said Thank You: cadpete
4 years 11 months ago #227133 by tommylight
Note to self: do not edit long posts ! :)
Here is a video that explains it much better than i do, just ignore the PLC parts and skip to 45 seconds.
The following user(s) said Thank You: Clive S, cadpete
4 years 11 months ago #227703 by cadpete
Thanks for the help. JT has let me know new stock is in so ordered 7i76e this morning. (4am)
4 years 4 months ago #245604 by deus
Replied by deus on topic Alternatives to 7i76
Hi
I am currently also looking for a MESA 7i76e. So if anybody has any hints where to get one that would be greatly appreciated.
@cadpete - Who did you mean by JT? I am also from Perth, Australia. ;)
4 years 4 months ago #245735 by andypugh
Replied by andypugh on topic Alternatives to 7i76
JT = mesaus.com
Time to create page: 0.420 seconds
