A axis position
3 years 9 months ago #263116 by tommylight
Replied by tommylight on topic A axis position
Wow
That's great image missing /media/kunena/emoticons/cheerful.png
+1
3 years 9 months ago #263181 by looping
Replied by looping on topic A axis position
I upgraded LinuxCnc to the last buildbot version and updated my INI file with :
[DISPLAY]
GEOMETRY = !AXYZ
Did I miss something ?
3 years 8 months ago #263542 by looping
The build (>=758) improved a bit, but still some work to be done : The shape of the path is now correct with or without an offset.
But the path remains located on the machine origin.image missing /media/kunena/emoticons/sad.png
[DISPLAY]
GEOMETRY = !AXYZ
3 years 8 months ago #263660 by andypugh
Replied by andypugh on topic A axis position
The only way I see round this is to add a "magic comment" that the preview could parse. Something like (ORIGIN, 100 0 0)
Or maybe an INI entry, but that couldn't be changed at runtime.
3 years 8 months ago - 3 years 8 months ago #263748 by looping
All paths are related to the current orgin. It should be the same in this case. Offsets are known and should be use.
I tried to touch the sources but I still don't understand where it should be done :
I can have the proper display with !AXYZ for the the program but the liveplot is still incorrect.
Also with this mod, the offset seems to be applied twice for the linuxcnc example xyzc
Last edit: 3 years 8 months ago by looping.
3 years 8 months ago #263749 by looping
liveplot image missing /media/kunena/emoticons/pinch.png
Time to create page: 0.080 seconds
