A axis position
- looping
- Thank you received: 10
26 Jan 2023 12:49 #262953
by looping
A axis position was created by looping
Hello
I'm just starting to play with 4 axis configuration and trying to mill 6 faces out of a 20mm rod.
In linuxcnc all looks good only when I don't have any G54 Z offset.
But if I have an offset on the Z axis, it looks strange.
Do I must move my machine origine to the A axis to be able to have a nice preview ?
- looping
26 Jan 2023 12:51 #262954
by looping
Replied by looping on topic A axis position
Files to reproduce
- Online
28 Jan 2023 11:34 #263099
Replied by andypugh on topic A axis position
The G-code preview assumes that the centre of rotation is the axis zero.
You just have to accept that the preview in rotary mode is nothing more than an indication. (The preview has no way to know where your axis of rotation is, the G-code does not include that information)
- looping
28 Jan 2023 11:52 #263102
by looping
I agree but the preview is just an indication but in this case it is misleading : On the second preview it may look like the path will be out of machine boundaries but in fact it is not.
The axis position, as it is machine dependent, should rather be in the INI fileThe preview has no way to know where your axis of rotation is, the G-code does not include that information)
- dgarrett
- Thank you received: 297
28 Jan 2023 13:48 #263108
by dgarrett
Replied by dgarrett on topic A axis position
2.9 and up:
> 10. Rotations applied after translations may use the "!" provision to act with
> respect to the current machine offset. Example: GEOMETRY=!CXYZ translates the
> control point to the X, Y, Z position and then performs a C rotation about the
> machine origin displaced by the current G5x,G92 X, Y, Z offsets. (Changing
> offsets may require a program reload).
Ref:
linuxcnc.org/docs/2.9/html/config/ini-config.html
github.com/LinuxCNC/linuxcnc/commit/c392629
Ref:
The following user(s) said Thank You: tommylight, Pro_El
- looping
28 Jan 2023 14:03 #263114
by looping
- Thank you received: 7504
28 Jan 2023 14:21 #263116
Replied by tommylight on topic A axis position
+1Wow
That's great
- looping
29 Jan 2023 14:00 #263181
by looping
I upgraded LinuxCnc to the last buildbot version and updated my INI file with :
[DISPLAY]
GEOMETRY = !AXYZ
Did I miss something ?
[DISPLAY]
GEOMETRY = !AXYZ
- looping
02 Feb 2023 13:23 #263542
by looping
- Online
04 Feb 2023 05:13 #263660
Or maybe an INI entry, but that couldn't be changed at runtime.
The only way I see round this is to add a "magic comment" that the preview could parse. Something like (ORIGIN, 100 0 0)The build (>=758) improved a bit, but still some work to be done : The shape of the path is now correct with or without an offset.
But the path remains located on the machine origin.
Moderators: piasdom
Time to create page: 0.281 seconds
