Milling machine endstop hardware selection?
- CrashOverride
07 Feb 2023 09:00 #263943
by CrashOverride
Milling machine endstop hardware selection? was created by CrashOverride
Converting a large knee mill, and curious what endstop hardware others are using. Would optical endstops be advisable over mechanical for longevity?
- Thank you received: 7504
07 Feb 2023 10:06 #263954
Replied by tommylight on topic Milling machine endstop hardware selection?
CrashOverride? Hackers, the movie?
That depends, is the machine going to use coolant?
If yes, most probably mechanical fully sealed or inductive ones, although inductive ones will have to be protected from debris.
- Thank you received: 4656
07 Feb 2023 17:09 - 07 Feb 2023 17:09 #263990
Replied by andypugh on topic Milling machine endstop hardware selection?
I use inductive, buried in the ways.
photos.app.goo.gl/bPETVs7sDLAK8a9r9 (during wiring)
And similarly on my lathe:
photos.app.goo.gl/yVMkdVpRTrHHyCvm6 (not normally visible, the ball nut has been disconnected for the photo)
Targets are shallow drilled holes.
Note that you need the "shielded" type for this to work, with the screw-threaded case reaching all the way to the end. The other type (with more plastic visible) will be triggered by the hole that they are in.
Last edit: 07 Feb 2023 17:09 by andypugh.
Moderators: piasdom
Time to create page: 0.430 seconds
