Mori Seiki MV-Junior Retrofit
- besriworld
- Thank you received: 92
19 Aug 2023 06:23 #278441
by besriworld
Mori Seiki MV-Junior Retrofit was created by besriworld
The project is in progress!
I am buying an old machine with a good reputation.
Specification:
Table dimensions 900mm x 410mm
Travel X560 ; Y410 ; Z460
Rapid feed rate X and Y 15m/min ; Z 12m/min
Ball screw dimensions 40x10mmP (X , Y and Z)
Main motor 3.7kw/5.5kw Max RPM 6000
Max Load on table 300kg
Weight 3.5T
Arrived at the new home
Dismantling of the Z axis:
Specification:
Weight 3.5T
The following user(s) said Thank You: scotth
- besriworld
19 Aug 2023 06:48 #278442
by besriworld
Replied by besriworld on topic Mori Seiki MV-Junior Retrofit
I will continue with photos .
Cleaning from the old oil.
Replacing the guides with new roller SCHNEEBERGER. Replace the ball screws with the suitable size and replace all support bearings 12pcs (for z , x and y)- 30TAC62 .
Dismantling, cleaning and replacement of bearings in the ATC. A few photos of the process
- besriworld
19 Aug 2023 07:00 - 19 Aug 2023 07:04 #278443
by besriworld
Last edit: 19 Aug 2023 07:04 by besriworld.
The following user(s) said Thank You: RotarySMP, tommylight, spumco
- besriworld
19 Aug 2023 20:32 - 19 Aug 2023 20:36 #278495
by besriworld
Each ball screw has 3 bearings 30TAC62 , the screw is secured with an additional body (grinding cylinder with dimensions of 40-60mm ).
New servo motors for spindle and axis
The drive is with Etercat and mesa cards for spindle and I/o port.
I decided to make a foundation as shown in the machine documentation.Because my foundation was too bad…
20 cm of gravel and 60 cm of concrete.
Last edit: 19 Aug 2023 20:36 by besriworld.
The following user(s) said Thank You: RotarySMP, tommylight, pommen, spumco, Unlogic
- leighd
30 Aug 2023 10:32 #279364
by leighd
Replied by leighd on topic Mori Seiki MV-Junior Retrofit
Looks great! I am looking to do the same soon.
May I ask where you are sourcing all your replacement parts from?
Thanks.
Thanks.
- besriworld
30 Aug 2023 19:32 #279411
by besriworld
Which part are you referring to?
Do you have the same machine?
- besriworld
22 Oct 2023 16:26 #283507
by besriworld
The following user(s) said Thank You: tommylight, GPtech
- GPtech
03 Jun 2024 06:15 #302226
by GPtech
Replied by GPtech on topic Mori Seiki MV-Junior Retrofit
Anymore updates?
I have an MV-40b with Fanuc 0m that might need converting soon
Anymore updates?
- besriworld
03 Jun 2024 09:30 #302229
by besriworld
There's nothing new. I'm working on the lathe from the other topic.
- 4ndr344
- Thank you received: 10
08 Jul 2024 13:28 #304665
by 4ndr344
Replied by 4ndr344 on topic Mori Seiki MV-Junior Retrofit
This might sound stupid. Ive just done a similar job as you although I didn't bother with any mechanical parts as my jr has been used in a school and is still like new, only problem I have is I have one pice of metal I can't find out where goes.
Do you have any idea where this goes.
Thanks in advance for any help!
Moderators: piasdom
Time to create page: 2.241 seconds
