Shibaura retrofit
21 May 2024 21:20 #301122 by Methier
Shibaura retrofit was created by Methier
Hi, I have a Shibaura machine and i want to retrofit but i wonder if the servo drives are analog, pwm or serial. I want to reuse the drives because they seems to work fine.
The machine controller is tosnuc 777-2.​​​​​​
Machine model VMC-55E
Servo drive models are:
AC14I-F
AC28F-D
AJ-28E
I can't find any info of them, pinout or something.Attached some pics of the drives.
Thank you
24 May 2024 01:55 #301274 by tommylight
Replied by tommylight on topic Shibaura retrofit
No info on those, made by Toshiba, so more pictures of every connector and wiring to it, board near the connector, etc.
Some of those will have writings on the cables inside the connectors.
Moderators: piasdom
