- Thank you received: 4
Y axis acts like it has backlash
- EragonPower
- Topic Author
2 years 4 months ago #303307
by EragonPower
Y axis acts like it has backlash was created by EragonPower
Hello everybody,
Bit of context: i've recently overhauled my CNC Router. Just moved to bigger rails on every axis, built a mineral casting (epoxy granite), to increase rigidity. It's not even a week since i've finished putting it together and i just started to machine some parts.
I had to stop the first program i ran as the first endmill ended up rubbing on the side of the part, melting the aluminum i was machining, thing that i found strange, as the part was only 15mm thick. On closer inspection i found that the part was shifted almost half a mm in the Y+ direction, which could have caused the endmill to rub on the finishing passes. Odd.
I've checked every screw on the Y axis and found none loose. I've checked whether the Y axis ballscrew bearing block nut could have been loose, thing that happened to me before, but again, everything is tight.
So i ran another part, different one this time, with a lot more travel along the Y axis. Result? The part was shifted over 2mm in the Y+ direction. On closer inspection i found out that the part presented a sort of stairstepping coinciding with the stepdowns in the roughing program, but each stepdown was shifted in the Y+ direction a bit, creating something like a real stair. Another strange thing is that this phenomenon only presented in the Y+ direction, another indication that the endmill was shifting right (Y+) on each stepdown.
Now, i've checked for backlash by pushing and pulling on the machine while measuring with an indicator for deflection. The machine was rock solid (i could move the machine by 0.01mm if i pushed with all of my strength, which for a DIY CNC is not bad i think).
I've than checked for backlash in the usual way, by setting an indicator at the end of travel, moving the axis over, than going back to zero. BINGO!
I found where my movement was going. Almost 0.2mm when moving the axis from 0 to 600mm and back, and this error was adding each time i've done 0-600-0.
I've checked the servo(the machine has IHS-60 integrated servos that i haven't retuned yet since the reassembly, i should), and it showed sporadic peaks of 15 pulse of "latency" or following error on the Y axis, usually it stayed between 3 and 7 though. Is this the problem? 15 pulses at 800 pulses/rev on a 5mm ballscrew results on a bit over 0.09mm of following error.
Now, following error refers only on a latency between what the controller thinks that the position is, and the real position.
Another thing that i've measured was the current draw from the motor, looking at the onboard current meter. It showed peaks of more than 17A, which for me is not real, or the unit of measure is not amps, as the servo is rated at 400W @ 48V and has an allowable peak of 15A, as for a parameter set inside of the motor controller.
And now i'm turning to this forum looking for ideas on what to check next. Tomorrow i will tear down the Y axis to check the motor coupler, but testing it, it didn't look like it was slipping at all.
Other simptoms that this might be something software/tuning related is that when E-stopping / disabling the machine, the X axis motors on the gantry move a bit, one in one direction and the other in the opposite direction. I should retune those too, but looking at the following error and the current draw they don't look like they are acting like springs, neither that they need retuning for high following error.
If anyone wants to look into this madness, i leave the link to the entire configuration of the machine.
github.com/EragonPower/LinuxCNCMachineConfiguration
Thanks to anyone in advance, even for only reading this post
- jimmyrig
- Thank you received: 42
2 years 4 months ago #303312
by jimmyrig
Replied by jimmyrig on topic Y axis acts like it has backlash
The x axis motors moving after estop is likely due to them not being perpendicular to the y axis. Adjust your homing offset settings in the ini file to tune this.
Sometimes things are bent (usually the main structural member) and the motors need to compensate for this and can cause the spring back you are seeing.
Seeing peaks of 17a isn't that weird if your accelerations are really high relative to the weight of your axis. Just make sure your average is decent.
However make sure things aren't too tight. Trying to eliminate backlash entirely can easily cause things to bind up. Easy way to check is to turn the axis by hand and make sure it isn't binding up anywhere. Sometimes the lead screw has wobble and can cause things to bind (can happen with just about any drive system) or the rails are bolted funny.
- EragonPower
- Topic Author
2 years 4 months ago #303325
by EragonPower
Replied by EragonPower on topic Y axis acts like it has backlash
UPDATE: Yesterday I checked every screw except for the one on the servo coupler connecting it to the ballscrew, as for checking it I needed to tear down the Y axis, so today I did exactly that, and guess what, IT WAS LOOSE. Tightening it resolved the issue entirely.
On the X axis though, the problem came out only after squaring the XY gantry, so it's probably not due to the non-squareness of the system. It could be that the side plates are not exactly flat and are forcing a bit of twist in the gantry.
In the future I'll keep an eye on motor current, to see if I need to lower accelerations etc, thanks jimmyrig.
I'll keep investigating, but for what regards this thread, I consider it closed
- jimmyrig
2 years 4 months ago #303328
by jimmyrig
Glad you found it!
Another tip, always use a thread locker on CNC machines, the extra hour and 5 bucks spent putting it together with that locker saves days of trouble shooting hard to find issues like this.
If nothing else (or the machine was assembled without thread locker) paint a line from the side of every bolt and about a half inch on the machine so you can identify bolts which loosened much easier.
- Thank you received: 426
2 years 4 months ago #303336
Replied by Cant do this anymore bye all on topic Y axis acts like it has backlash
We used to call that "cocky shit" as it looks like what cockatoos drop. But I guess that would be too triggering for the most recent generations lol.
Time to create page: 0.056 seconds
