servo motor for a spindle
  • PhilipME
  • PhilipME's Avatar Topic Author
  • Elite Member
  • Elite Member
29 Aug 2024 14:55 #308940 by PhilipME
servo motor for a spindle was created by PhilipME
I bought 2kw servo motor long time back. like this one in the link
www.aliexpress.com/item/32868022627.html...in.36.18441802DpVtla
I want to use it as a spindle (no tapping )
Can someone direct me to where I find how to wire this creature?
I am using break-out-board, and BT-30 power head
Second question
Does this motor have sufficient axial bearing to mill directly without the power head?
Good day
Philip
29 Aug 2024 15:50 #308946 by OT-CNC
Replied by OT-CNC on topic servo motor for a spindle
I would never use a servo motor as a direct spindle unless it's designed to do so. What you show probably has standard grade electric motor bearings. A proper spindle has angular contact bearings designed to take axial and radial loads.
Also, it would be hard to control runout on anything mounted to the shaft for tool holding. I think pocket NC had something along those lines but I don't have experience with them. Always thought of that spindle to be a poor design. Probably fine if you're doing wax or hd foam models.
The following user(s) said Thank You: PhilipME
29 Aug 2024 16:40 #308952 by spumco
Replied by spumco on topic servo motor for a spindle
Need more detail.
Post a copy of the user manual please, as well as your BOB manual.  If you're using a Mesa card, please identify it and how you've connected your BOB.
29 Aug 2024 19:11 #308964 by COFHAL
Replied by COFHAL on topic servo motor for a spindle
Yes you can use it set to speed mode.
  • PhilipME
  • Elite Member
  • Elite Member
29 Aug 2024 22:50 #308987 by PhilipME
Replied by PhilipME on topic servo motor for a spindle
Need more detail.
the break out board is just a simple db 25 like the one in the link
store.fut-electronics.com/products/5-axi...-mach3-parallel-port
The manual for the servo driver
machmotion.com/documentation/Drives%20-%...TSTA-User-Manual.pdf
for speed mode, I thought it will be as simple as vfd spindle, on/off and analog for speed control
  • PhilipME
  • Elite Member
  • Elite Member
30 Aug 2024 05:01 #309001 by PhilipME
30 Aug 2024 05:42 - 30 Aug 2024 05:45 #309004 by tivoi
Replied by tivoi on topic servo motor for a spindle
hi why you dont use spindle servo ?
induction motor with closed loop control, can run position/ speed control
Last edit: 30 Aug 2024 05:45 by tivoi.
30 Aug 2024 05:58 #309005 by tivoi
  • PhilipME
  • Elite Member
  • Elite Member
30 Aug 2024 07:18 - 30 Aug 2024 07:23 #309007 by PhilipME
vi.aliexpress.com/item/1005006990514922....ller%7Cquery_from%3A
Thanks for the reply
never knew such thing existed. Actually I asked in several forums including industrial arena, but unfortunately did not get such reply
will the spindle servo have enough torque at low speed? I may have to go low speed for facing toolpath (milling)
Last edit: 30 Aug 2024 07:23 by PhilipME.
30 Aug 2024 08:23 - 30 Aug 2024 08:23 #309010 by tivoi
Most industrial machine spindle motors are induction type.
can facing and riggid tapping
it is special desgin . Rate about 1500 rpm only, and max is 8000rpm or 10 to 12krpm
Last edit: 30 Aug 2024 08:23 by tivoi.
Moderators: piasdom
Time to create page: 0.195 seconds
