servo motor for a spindle
- PhilipME
- Thank you received: 14
29 Aug 2024 14:55 #308940
by PhilipME
servo motor for a spindle was created by PhilipME
I bought 2kw servo motor long time back. like this one in the link
www.aliexpress.com/item/32868022627.html...in.36.18441802DpVtla
I want to use it as a spindle (no tapping )
Can someone direct me to where I find how to wire this creature?
I am using break-out-board, and BT-30 power head
Second question
Does this motor have sufficient axial bearing to mill directly without the power head?
Good day
Philip
Second question
Good day
Philip
- OT-CNC
- Thank you received: 75
29 Aug 2024 15:50 #308946
by OT-CNC
Replied by OT-CNC on topic servo motor for a spindle
I would never use a servo motor as a direct spindle unless it's designed to do so. What you show probably has standard grade electric motor bearings. A proper spindle has angular contact bearings designed to take axial and radial loads.
Also, it would be hard to control runout on anything mounted to the shaft for tool holding. I think pocket NC had something along those lines but I don't have experience with them. Always thought of that spindle to be a poor design. Probably fine if you're doing wax or hd foam models.
The following user(s) said Thank You: PhilipME
- spumco
- Thank you received: 896
29 Aug 2024 16:40 #308952
by spumco
Need more detail.
Post a copy of the user manual please, as well as your BOB manual. If you're using a Mesa card, please identify it and how you've connected your BOB.
Replied by spumco on topic servo motor for a spindle
Need more detail.
- COFHAL
- Thank you received: 62
29 Aug 2024 19:11 #308964
by COFHAL
Replied by COFHAL on topic servo motor for a spindle
Yes you can use it set to speed mode.
- PhilipME
29 Aug 2024 22:50 #308987
by PhilipME
the break out board is just a simple db 25 like the one in the link
store.fut-electronics.com/products/5-axi...-mach3-parallel-port
The manual for the servo driver
machmotion.com/documentation/Drives%20-%...TSTA-User-Manual.pdf
for speed mode, I thought it will be as simple as vfd spindle, on/off and analog for speed control
Replied by PhilipME on topic servo motor for a spindle
Need more detail.
- PhilipME
30 Aug 2024 05:01 #309001
by PhilipME
- tivoi
- Thank you received: 20
30 Aug 2024 05:42 - 30 Aug 2024 05:45 #309004
by tivoi
Replied by tivoi on topic servo motor for a spindle
Last edit: 30 Aug 2024 05:45 by tivoi.
- tivoi
30 Aug 2024 05:58 #309005
by tivoi
- PhilipME
30 Aug 2024 07:18 - 30 Aug 2024 07:23 #309007
by PhilipME
vi.aliexpress.com/item/1005006990514922....ller%7Cquery_from%3A
Thanks for the reply
never knew such thing existed. Actually I asked in several forums including industrial arena, but unfortunately did not get such reply
will the spindle servo have enough torque at low speed? I may have to go low speed for facing toolpath (milling)
Last edit: 30 Aug 2024 07:23 by PhilipME.
- tivoi
30 Aug 2024 08:23 - 30 Aug 2024 08:23 #309010
by tivoi
Most industrial machine spindle motors are induction type.
can facing and riggid tapping
it is special desgin . Rate about 1500 rpm only, and max is 8000rpm or 10 to 12krpm
Last edit: 30 Aug 2024 08:23 by tivoi.
Moderators: piasdom
Time to create page: 0.526 seconds
