Chinese Servo Drive Calibration XP200
- Walkahz
- Thank you received: 7
02 Sep 2024 11:40 #309206
by Walkahz
Chinese Servo Drive Calibration XP200 was created by Walkahz
Hi All
Have just brought a chinese 2.6 kw braked servo to run the z axis of my Deckel FP4.
The smaller 1kw servos i brought a few months ago came with pre wired tails to connect up to my mesa 7i96S and i have had them up and running fine.
This new driver however came with a bare plug and some chinese instructions
I have wired up the new plug according to the wiring with my step and dir signals going to pins 37 39 41 and 43
Fired up linux cnc to no result.
Brake was released manually before hand.
Tested using one of my x and y outputs also to see if it was a configuration error which it doesnt seem to be.
once the brake is released the motor can still be spun by hand almost like the drive is not sending power to the motor.
Ive had the motor turning under a test cycle after which the motor shaft will lock up like it should.
I also had a thought that this driver might need an enable signal which i tried to replicate by bridging pins 11 and 9
any other ideas as i am running out.
- besriworld
- Thank you received: 92
02 Sep 2024 14:06 #309211
by besriworld
Replied by besriworld on topic Chinese Servo Drive Calibration XP200
Yes, the enable signal is needed. But you need to set up the driver and motor first.
The following user(s) said Thank You: Walkahz
- Thank you received: 7488
02 Sep 2024 14:34 #309213
Replied by tommylight on topic Chinese Servo Drive Calibration XP200
Yes enable must be connected and functioning for the drive to work, that is SON pin 9 Servo Enable.
- Walkahz
03 Sep 2024 03:14 #309249
by Walkahz
Replied by Walkahz on topic Chinese Servo Drive Calibration XP200
I think I know where I have gone wrong.
I was working of a chinese translation of the above and thought the driver was suppling its own power. Now ive read the english one above better i need to supply 24v power in to pin 11 and earth pin 9 to make it work.
Will try when i get home and hopefully get some action.
- Walkahz
09 Sep 2024 00:00 #309699
by Walkahz
Thanks all
Got it Fired up with supplying power as above.
Thanks for being a bouncing board for my out loud thoughts!
09 Sep 2024 00:23 #309700
You are welcomed, always.
- Srwils
15 Jan 2025 02:27 #318992
by Srwils
Replied by Srwils on topic Chinese Servo Drive Calibration XP200
I just received a XP200-30pl servo drive and I am now looking for a manual in English. The documentation sent was a one page sheet all in Chinese I noticed in this thread that there is a I/O drawing in English. If someone has a English manual for the XP200 please send let me know.
Scot Wilson
Scot Wilson
- rthorntn
- Thank you received: 6
31 Jan 2025 04:25 #320204
by rthorntn
Replied by rthorntn on topic Chinese Servo Drive Calibration XP200
Apologies for hijacking this thread.
I have one of these XP200 drives that I'm about to start using for a project, I want to use it in speed mode, so set it to a certain RPM and have it try to maintain that RPM under varying load.
What's the easiest way to set it up in speed mode without a computer (I might add a computer later), I was envisioning connecting up a potentiometer but I'm guessing it's probably not going to be that easy, as this thread is saying I need to supply 24v to enable it or is that only for STEP/DIR?
Thanks!
Thanks!
- rthorntn
03 Feb 2025 01:38 #320468
by rthorntn
- vre
- Thank you received: 17
12 Jun 2025 15:06 #330210
by vre
Replied by vre on topic Chinese Servo Drive Calibration XP200
Have you set up this drive ?
Performs well ?
Performs well ?
Moderators: piasdom
Time to create page: 0.184 seconds
