Fanuc 2S AC spindle motor on Delta C2000+
2 years 1 month ago - 2 years 1 month ago #309680 by spumco
I'm really sorry for my earlier knee-jerk post.  The newer versions of the Fanuc spindle motor are PMs, so it's possible that yours is also a PM.
Last edit: 2 years 1 month ago by spumco.
2 years 1 month ago - 2 years 1 month ago #309693 by routerman22
I did the "short a pair of wire" test but there is no detent at all so must be an induction motor.
Also changing the accell to 60 seconds for example does not change the behavoir.
I have a quick chat with a delta guy tomorrow, perhaps he has some insight.
Last edit: 2 years 1 month ago by routerman22.
2 years 1 month ago - 2 years 1 month ago #309701 by tivoi
drive  have 3 control loop
the first is current loop can auto tuning with motor parameter
second is speed loop and third is position loop if need
delta C2000 look like have speed loop auto tuning, but maybe need mod by manual
Last edit: 2 years 1 month ago by tivoi.
2 years 1 month ago - 2 years 1 month ago #309817 by besriworld
I think there is a mistake here.  Rated Frequency should be for 1500rpm
ps. Parameter 01-00 specifies the maximum motor frequency
Last edit: 2 years 1 month ago by besriworld.
The following user(s) said Thank You: tivoi
2 years 1 month ago #309822 by tivoi
motor rate fequency is 50hz
Time to create page: 0.242 seconds
