Maho mh800w retrofit
11 months 2 weeks ago #338327 by djdock99
Replied by djdock99 on topic Maho mh800w retrofit
Been trying to get the estop and machine on circuits working properly today with help from marks mh400e information which he kindly sent to me.
just wondering if the older mahos have the same estop chains and components?
8 months 3 weeks ago #342603 by djdock99
Help me please????I have spent 3 days trying to get linuxcnc to power on the Maho with no success.Where i am at. With linuxcnc open and the machine released from estop i can manually latch relay 19k1 by holding on the contactor with a screw driver. When i do this the whole machine powers up and everything is working perfectly. the drives are enabled the linear scales are reading correctly. the door open closed switches are all working correctly but the x and z servos are rotating slowly but smoothly. Then when i update the hal file to electronically latch 19k1 with f2 it will not hold and drops relays straight away.
8 months 3 weeks ago #342604 by djdock99
inputs and outputs
8 months 3 weeks ago #342613 by tommylight
Replied by tommylight on topic Maho mh800w retrofit
.... i can manually latch relay 19k1 by holding on the contactor with a screw driver.
Never smart to do that to machines.
.... but the x and z servos are rotating slowly but smoothly.
This means that LinuxCNC has no control over the servo drives, usually incorrect or missing wiring, like are the encoders wired to Mesa and do they work correctly counting up/down on the LinuxCNC DRO ?
What error does LinuxCNC show when that happens?
I would bet it shows "joint.n.following-error" as noted on my second reply.
You are working on a complicated machine, so it is imperative to follow instructions strictly and as listed in priority.
See this for wiring and testing:
forum.linuxcnc.org/10-advanced-configura...to-example-mesa-7i77
And for network and WiFi to work at the same time, see here
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
8 months 3 weeks ago #342616 by djdock99
thanks tommy for the reply. regarding pushing the contactors, i hade to prove that the machines electronics are working properly and that the push button 3sh1 which powers 6a1 safety relays temporarily until 19k1 is latched was working correctly. all the safety systems of the machine are not be touched. similar to Rotarysmp's mh400 retrofit.
Linear scales are reading correctly on the dro and as you can see from the ini file posted above i have accurately populated the scales values.
regarding the indramat drive signals i bet your right and i know i have something wrong here but im having trouble figuring out what. +10 and -10 wires are connected to the 7i97ts and i have left the original drive enable circuit untouched as this is handle by a contactor called 7k1 whose coil is pulled when 19k1 relay has been latched leaving mahos estop and error indictor logic untouched. can this work?
linuxcnc does not show joint.n.following-error but it did before i added an extra ground from +10-10 cable sheathing cables sheathing.
contactors fire and back to estop errors. i know im doing something wrong but writing this and try to explain whats going on might help. thanks for your help
8 months 3 weeks ago #342632 by VRNF
Replied by VRNF on topic Maho mh800w retrofit
Sounds like you have two separate errors.to clarify, when you try to start the machine contactors are closing? If so, which?
For the servos, can you post how you connected the indramat +/- 10V wires to 7i97T terminal block?
Time to create page: 0.257 seconds
