Deckel FP4A Retrofit
- Beovoxo
- Thank you received: 30
01 Jan 2025 17:05 #317788
by Beovoxo
Deckel FP4A Retrofit was created by Beovoxo
I just bought a used mill for 330 Euro and now the fun begins
I have planned to do a full EtherCAT Servo build, with the Bechhoff moduls or similar.
More will be posted soon when the unit is placed on the floor and cleaned. I have already stripped some of the guards, panels away to get more room for cleaning. Also the control unit and the "electrical cabinet" are removed.
Best regards and Happy New Year From Denmark.
The following user(s) said Thank You: tommylight, besriworld
- Thank you received: 7449
04 Jan 2025 14:23 #318072
Replied by tommylight on topic Deckel FP4A Retrofit
Nice find and to damn cheap, you lucky b....
Good luck with the retrofit, there are several similar machine logs here in case you did not see them, but i think all use Mesa controllers with normal servo drives, normal as in not EtherCAT. Some use the old existing drives, IIRC
- Beovoxo
05 Jan 2025 00:47 #318134
by Beovoxo
Replied by Beovoxo on topic Deckel FP4A Retrofit
thx
i have already read most of the logs, yes i think almost all uses the mesa but i think it will be a nice thight setup with the ethercat and a beckhoff ek1100 + 2 ethercat IO boards.
- Beovoxo
05 Jan 2025 00:54 #318137
by Beovoxo
- Beovoxo
08 Jan 2025 13:22 #318402
by Beovoxo
- Beovoxo
02 Feb 2025 01:37 - 02 Feb 2025 01:45 #320379
by Beovoxo
Today I finally got the Beckhoff Ek1100 running under linuxcnc with ethercat
. It was a steep sloop to go on, but I finally got it . I had a lot of troubles with broken links and such under installation, so it ended up with like 15 reinstalls. and then, like a grenade hit the new image was uploaded and most of the things worked a lot smoother:)btw if any out there knows how to send commands from the ek1100 to the cx unit plz write some info:) or else it will just be controlled via outputs.. if its a lost course i am planning to run the cx unit as a normal plc instead. it will run transmission/gears and spindle, lights and such.
Have a nice day all
Have a nice day all
Last edit: 02 Feb 2025 01:45 by Beovoxo.
- Thank you received: 4122
02 Feb 2025 12:21 #320407
Replied by rodw on topic Deckel FP4A Retrofit
The cx9010 is normally set up an Ethercat master. Linuxcnc uses a different Ethercat master (and a whole lot more) too.
It would only be useful if you could install Debian and Linuxcnc on it, it could be used but I suspect that will not be possible due to lack of resources
- Beovoxo
02 Feb 2025 21:57 #320454
by Beovoxo
Ok thx
then i will just run it as a "normal" plc with I/O outputs from the ek1100 to control the transmission
thx
- Beovoxo
11 Feb 2025 23:49 #321297
by Beovoxo
- Beovoxo
24 Feb 2025 17:01 #322507
by Beovoxo
Moderators: piasdom
Time to create page: 4.841 seconds
