Hi Andy,
Good day. From what i have gathered in the user manuals available in the internet and checking the existing connection from the servo controllers to the non-functioning acramatic 2100 controller,
each servo controller (X, Y, Z, and Spindle) has
1) +-10V inputs (i assume to drive the servo motors)
2) An A & /A, B & /B, and Z & /Z encoder outputs.
I was thinking of connecting the +-10V servo inputs to the 7i77 by its TB5 outputs namely, ENA0+-, ENA1+-, ENA2+-, and ENA3+-.
Then connecting the servo encoder outputs to the 7i77 by its TB3-TB4 inputs namely, QA0 & /QA0, QB0 & /QB0, IDX0 & /IDX0, for all axes and the spindle.
If that is correct, my only problem now would be the configuration under linuxcnc which I have no idea where to begin.
As I have already purchased the Plug-N-Go Kit (7i77 + 6i25) from Mesa, I would like to use them. But will look into your suggestion since they have more pins. Also, it would be generally hard for me to purchase additional boards since I am from the Philippines.
Thank you very much for your assistance.
