- Thank you received: 61
Yes.A not properly crimped plug or semitight srew termnial might cause a problem as well?
Any motor wire.Or does the damage only occur when all four wires are disconnected at same time?
What system? The drive will know, motors are inductors and disconnecting powered inductors cause huge spikes that very often end in dead equipment.I would guess the system does not know if I did it or it just happened.
because I might have damaged a drive or two without beeing aware of the importance of the wiring.
