Looking really good so far, although without actually testing with Mesa attached is much safer for deciding, but it is a go for sure from those tests.
I had several T40/T41/T42/T43, they all worked fine with Ubuntu 10.04 and LinuxCNC 2.5/2.7 using parallel port.
I had Lenovo T420S it was not usable, now it seems with new kernels it is quite good.
I had Lenovo X220 it was unusable, now it seems with new kernel it is quite good.
I have X240 in use on a production machine it works fine with Mesa
I have T470 with touchscreen was used on production machine for over a year or two, works fine with Mesa
And so do X1 Yoga and Yoga 370.
There is a topic on laptops, so if it ends up working with Mesa you should add those there.
Thank you.
forum.linuxcnc.org/18-computer/54369-use...ernet-boards?start=0
