Used Laptops tested with LinuxCNC and Mesa Ethernet boards
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
06 Nov 2024 20:28 #313953 by tommylight
Do NOT post here about issues with Laptops, post only tested and working ones.
For issues start a new topic, BUT do keep in mind laptops are not advised to use on production machines due to latency issues inherent from power saving options built into them.
All test are done on a production machine, time in use noted for each one below, as are BIOS settings changed and suitability for use in testing or hobby or production environment.
  • Moderator
  • Moderator
06 Nov 2024 20:29 - 11 Jan 2025 13:44 #313954 by tommylight
Lenovo ThinkPad T470 with touchscreen and built in RJ45 connector:
-In use for over a year running LinuxCNC 2.8 on Linux Mint 19.3 and PlasmaC on a production machine, wired to Mesa 7i92, complains about latency with 1000000 servo period but never fails, never drops the connection and never messes up.
-No GRUB changes, no isolcpus or anything, probably would get rid of the warning if used.
-Plugging and unplugging power does not cause issues
-Using it on batteries does not cause issues
Will add BIOS stuff and videos/pictures later.
Edit:
Video
youtube.com/shorts/ciVcxrlmMIA?feature=share
Last edit: 11 Jan 2025 13:44 by tommylight. Reason: added youtube
  • Moderator
  • Moderator
06 Nov 2024 20:29 - 04 Apr 2025 12:00 #313955 by tommylight
Lenovo ThinkPad X240, built in RJ45 connector:
-LinuxCNC 2.8 on Linux Mint 19.3, Mesa 7i92 on a production machine, very short use but so far no complaints at all
-No GRUB changes, no isolcpus, no changes to BIOS, nor anything else
-Plugging and unplugging power does not cause any issues
-Running on batteries does not cause issues
-Used for a 5 hour run and left two days on, no issues, no warnings, no disconnects.
Had two of these, they seem to have bad issues with batteries where if any of the two (internal and external) batteries is empty, the laptop will not turn on at all, needs several hours plugged in to actually turn on.
Do not let the batteries go empty.
Last edit: 04 Apr 2025 12:00 by tommylight. Reason: more info
  • Moderator
  • Moderator
06 Nov 2024 20:29 - 14 Dec 2024 01:11 #313956 by tommylight
Lenovo ThinkPad Yoga 370, Intel Core i7 7600U, 16GB RAM, 512GB NVME
-TouchScreen as it is laptop/tablet combo,
-no RJ45 connector,
-tested using a USB-A to GigaBit Ethernet adapter
-LinuxCNC 2.10 on Linux Mint 22 with RT kernel 6.10.12, Mesa 7i92 on a production machine,
-No GRUB changes, no isolcpus nor anything else, no BIOS changes
-complaints about latency whenever sound is used, but does not loose or drop connection,
==disabling hyperthreading and Intel AMT gets rid the warnings, but still rarely it does complain
-Plugging power does cause latency warning, but machine continues to work, and uplugging does not.
-isolcpus=3 and =2,3 did not help
-disabling TPM does NOT help much
==disabling SGX and virtualization DOES help a lot,
-no more warnings even playing videos during running of LinuxCNC and doing other stuff,
-did not test youtube as WiFi does not work with this kernel
-no more issues with servo period 1mil at all, except when plugging power
Video:
www.youtube.com/shorts/__zn74D7OyM
Last edit: 14 Dec 2024 01:11 by tommylight. Reason: more info
  • Moderator
  • Moderator
06 Nov 2024 20:30 - 06 Nov 2024 20:54 #313957 by tommylight
Lenovo ThinkPad R61E, built in RJ45 connector, very old
-This is with only 1Gb of RAM, Linux Mint 19.3 XCFE, kernel 4.16.12-rt5-kona-rt, single core processor at 2GHz.
-Using 4.9.47-rt37-kona-rt kernel the latency is much better, and can run Linuxcnc through ethernet connected to a 7i92 for 2 days without latency issues.
-Overall, a usable laptop for machine control, especially with more memory. No battery so no info if removing the power would cause latency errors.
Added:
Using this laptop for several weeks now, no issues so far, it works nicely and does not cause latency spikes even under load.
Last edit: 06 Nov 2024 20:54 by tommylight.
  • Moderator
  • Moderator
06 Nov 2024 20:31 #313958 by tommylight
Acer Switch 5 tablet
  • Moderator
  • Moderator
06 Nov 2024 20:31 #313959 by tommylight
Dell very old laptop with parallel port
  • Moderator
  • Moderator
06 Nov 2024 20:32 - 24 Mar 2025 15:52 #313961 by tommylight
Lenovo X1 Carbon Yoga laptop/tablet, no RJ45, touch screen, foldable tablet, 14"
-no RJ45 connector,
-Plugging and unplugging power does cause latency warning, but machine continues to work
- WiFi does not work with this kernel
No video yet, will update when i get to it.
Last edit: 24 Mar 2025 15:52 by tommylight. Reason: more info
  • Platinum Member
  • Platinum Member
06 Nov 2024 23:39 #313975 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Used Laptops tested with LinuxCNC and Mesa Ethernet boards
ytutgfhfgfghfg
Is that the i5 or Core Duo one ?
  • Moderator
  • Moderator
07 Nov 2024 00:09 #313979 by tommylight
ytutgfhfgfghfg
LOL
The following user(s) said Thank You: Cant do this anymore bye all
Time to create page: 0.334 seconds
