Used Laptops tested with LinuxCNC and Mesa Ethernet boards
04 Feb 2025 05:09 - 04 Feb 2025 05:18 #320572 by GeckoWorks
Thanks man, if I renege on my touchscreen obsession, I will keep this one in mind;)
Did a quick search on the used market already and quite a few of them around the USD70 mark. Looks to still have the ethernet port, too.
As for the touchscreen, I was hoping that ProbeBasic (lathe) would make it easier - but maybe still too small on a 14'' screen (I have a 22'' for the mill waiting to be set up). On first glance Gmoccapy seems to have smaller buttons but have to look into that some more.
Last edit: 04 Feb 2025 05:18 by GeckoWorks.
13 Feb 2025 21:28 #321481 by Boogie
Gents,
quick question - is laptop as below good for LinuxCNC + PlasmaC + Mesa 7i96 (or other Mesas)?
Lenovo ThinkPad T470s
Processor: Intel Core i7-6600U (2,6 GHz, turbo 3,4 GHz)
512GB SSD NVMe
RAM: 16GB DDR4
Grafika HD Graphics 520
Screen: 14", IPS, 1920x1080, matt, touchscreen
I can have it for 235 Euro.
I'm bit worried about screen size - is 14" comfy to operate in touch mode?
Thanks!
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
13 Feb 2025 21:55 #321485 by tommylight
Same laptop exactly, but using PlasmaC on Linux Mint 19.3
www.youtube.com/shorts/ciVcxrlmMIA
Next video under it is Lenovo Yoga 370 with QtPlasmaC also with touchscreen
www.youtube.com/shorts/__zn74D7OyM
The following user(s) said Thank You: Boogie
14 Feb 2025 10:10 - 14 Feb 2025 10:59 #321527 by GeckoWorks
I am wondering the same about the size.
Thing is, I have only just started my Lcnc journey a few days back by hooking up a 22'' Dell touch screen and at least for Probe Basic, I think I will be glad I didn't go a lot smaller. I feel like I could perhaps go to 19'', not sure 17'' though a few have mentioned 17'' works for them. But then all the regular Linux stuff, like log-in, drop downs and shut down gets tiny. But maybe that's OK as you don't use it much - and on a laptop, you still have your trackpad handy.
I think what I am trying to say is that for a PC, if you intend to not have a keyboard/trackpad/mouse, a bit bigger is probably better. For a laptop, depending on the screenset/UI, 14'' could be OK.
Last edit: 14 Feb 2025 10:59 by GeckoWorks.
The following user(s) said Thank You: tommylight, Boogie
  • Moderator
  • Moderator
08 Mar 2025 22:35 #323542 by tommylight
22 Mar 2025 06:38 #324522 by Boogie
Thanks guys. I ended up taking T470 with touch screen. Added Linuxcnc along with already existing Win and 7i96 works with no issues (on the table for now). Just received 7i95T today to have some fun but this requires some deeper tweaking - for separate topic. Thanks again - computer topic solved for me.
The following user(s) said Thank You: tommylight, GeckoWorks
  • Moderator
  • Moderator
24 Mar 2025 15:55 #324791 by tommylight
  • Moderator
  • Moderator
04 Apr 2025 12:01 #325678 by tommylight
12 Jul 2025 13:26 #331728 by GeckoWorks
So, I noticed no wifi on any of the Lenovo laptops... That's a bummer as I was hoping to sync files and not have to transfer with USB sticks anylonger.
Is it only the internal wifi that's not working and whetjer popping in a USB wifi adapter would work?
  • Moderator
  • Moderator
12 Jul 2025 13:46 #331729 by tommylight
Some WiFi adapters do work, some do not, there is no easy way of figuring out except testing.
Replacing the RT kernel does work though, i had to change to 6.13 for WiFi to work.
Strange as T470 has 4.19 RT (i think) kernel and WiFi works.
The following user(s) said Thank You: GeckoWorks
Time to create page: 0.243 seconds
