Trouble probing 1Vpp signal from Heidenhain LS403 with oscilloscope
1 year 7 months ago #325478 by PCW
Yes, a missing power supply may be the issue
All 7I77 encoder circuitry is 5V, so you would
need a separate 12V supply.
Do you have the converter manual? it should show
the 12V connection.
1 year 6 months ago #325701 by workshop54
Yes, the missing power supply was the issue. I was being too careful in my attempt not to blow up the Heidehain cards, but now it works.
I have hooked up all three encoders and for the first time I can see some movement in the LinuxCNC UI.
Thanks for your help again.
1 year 6 months ago #325711 by andypugh
The 0V, 5V and 12V pins highlighted look like test points to me. I wouldn't expect them to be scattered about the board like that if they were power inputs.
1 year 6 months ago #325958 by sivaraj
As for as I know Heidenhain LS403 is a 11uA signal . Not 1Vpp.
Please check the datasheet
Time to create page: 0.245 seconds
