Hi All,
Since some time I'm the proud owner of a 1994 Fadal VMC15, still in working condition.
However as it's equipped with the Baldor SWEO drive, known to die at a certain moment in time, with that same risk on the other electronics, I want to be prepared for a retrofit.
Searching this forum, I found lots of bits & pieces but not a complete 'how to retrofit guide' yet, also due so many different options / choices available for a retrofit.
My Fadal is currently equipped with DC servo motors and "Glentek GA377F-5" analog DC servo drives, the 7500RPM spindel and Baldor SWEO spindel drive and the 21 tools umbrella tool changer.
My initial plan is to keep the DC servo setup including the original resolvers and drives, replace the Baldor SWO by a modern VFD and hook up the machine to MESA cards under LinuxCNC control.
According to some experts, active at this forum, such setup should be very well doable as others did this trick already in the past.
Therefore I'm looking for advice on which MESA cards make best sense, how to hookup the servo's, how to deal with the VFD replacement and finally the tool changer setup.
Your thoughts, ideas and advice are deeply appreciated.
