Mecanumeric MF2040 LI retrofit (Pantograph)
- jackj120
26 May 2025 21:43 #329181
by jackj120
Mecanumeric MF2040 LI retrofit (Pantograph) was created by jackj120
Hi everyone,I'm planning a retrofit for my Mécanumeric MF2040 (large-format pantograph) i'll dismantle all the eletronic and leave the structure. After some research, I’m considering the following setup and would appreciate advice or feedback:Controller & Interface:
- LinuxCNC running on an old (but reliable) PC
- Mesa 7i76e Ethernet motion controller
- 3x Delta B2 Servo Motors (220V, 750W, 2.39Nm, 3000rpm, ECMA-C20807RS)
- Alternative: 3x Leadshine ELM0750DH80E-SS
- Z-axis motor: Still evaluating options
- The machine is mainly used for cutting and engraving (pantograph work, large panels).
- Does this setup sound suitable for a machine of this size and type?
- Any experience with these servo motors (Delta B2 vs Leadshine)? Reliability, tuning, integration?
- Suggestions for the Z-axis motor?
- Any compatibility issues or tips when using LinuxCNC with the Mesa 7i76e and these servo drives?
- Thank you received: 1476
27 May 2025 11:47 #329212
Replied by Todd Zuercher on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Presuming there is nothing wrong with the original servo systems, then usually the best option is to reuse them. You will need to figure out how the existing cnc controlled the servos. If they were using step/dir signals then the 7i76e should be a good option for the retrofit. If the servos were commanded using analog signals or some other way (such as some kind of serial bus), then some other hardware might be more appropriate.
- Hastrh2o
- Thank you received: 6
27 May 2025 14:36 #329224
by Hastrh2o
Replied by Hastrh2o on topic Mecanumeric MF2040 LI retrofit (Pantograph)
You can use the old drivers as Todd said. But, sometimes, changing everything is easier. I already kept old servos on a retrofit, then two years after I changed them because there were damaged .
Delta B2 are ok.
Delta B2 are ok.
- jackj120
27 May 2025 19:15 #329259
by jackj120
Replied by jackj120 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
So,when bought the machine i started with the idea of keeping the machine as it was, but after a week of figuring out how the old system work, it let me do only one job then the motor of the y axis broke and leaved me. So now i was thinking a retrokit to mount on my machine because this have to work hard and last. So idk i can change all the brain and use linuxcnc and leave 3 motors and buy another one new and with time and money i can change all of them . Or i can buy new motors and i don't touch it ever again(only for maintenance ).
Btw guys do you have a nice shop were to buy servo motors like the Delta B2 (ship in europe) i saw the motors on Namicam and Motion Control products, seem's good placees idk about the price but seem good pricing . And i need an advice leadshine if it's a good product for professional work . Because they are more cheap than Delta and i found them at really good price.
Thank's for your answers.
- Hastrh2o
27 May 2025 20:47 #329272
by Hastrh2o
I have read your description on usinages.com (I'm french).
I have bought Delta motors from Movitecnic in France, they are really helpful and have good prices.
I used Leadshine on stepper system only, it was ok.
- samlevy0515
28 May 2025 08:50 #329298
by samlevy0515
Replied by samlevy0515 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
If you want 90% of Delta's performance at 60% cost, pick Leadshine.
- jackj120
28 May 2025 08:54 #329299
by jackj120
Hi, yes im the same guy , the machine its giving me some problems , btw if i can ask how much did you paid them ? I saw them for ~400 the motor and ~400 the drive. Leadshine seem a good product but idk i'ld like if someone can guarantee them for a professional work as the Delta , they seem pretty good at a really good price.
- jackj120
28 May 2025 08:58 - 28 May 2025 09:00 #329300
by jackj120
Good to know samlevy0515 , do you know a good place were to buy them ? I found them on the sites that i named .
Last edit: 28 May 2025 09:00 by jackj120.
29 May 2025 10:00 #329358
My experience with issues with servos on older machines, has been. probably 70% of the time servo problems are usually cabling issues, about 20% a problem with the drive, and maybe 10% a motor problem. Intermittent problems are almost always cable related, and most servo motor alarms from the drive are also usually cabling issues. Check any cables that move or are flexed regularly, as well as connections at plugs, cord grips, and pinch points.
As to servo replacement options, I think Delta is nice, but Leadshine is nearly as good. Be careful of Chinese knockoffs if buying from questionable 3rd party venders.
- jackj120
29 May 2025 10:38 #329360
by jackj120
Hi Todd,
I’ve checked everything—the only thing left is the motor encoder, and a lot of people, including an electrician, told me it’s likely the problem. I’ve tested all the cables (several times), the controller, and I’ve even done parameter resets. So, It must be the encoder , because i've powered the motor with a power supply and it works.Just to clarify: I’m not doing the retrofit only for the motor. It’s because I’ve been talking to a guy who used to work on the same machine, and he said there are serious issues with the Z axis ,it doesn’t save its position. Actually, before the machine broke, I had experienced this issue myself.Over the last few days, I did some research and found a good shop online Variumetrum and i have done some research and seem's good so here my choices:
On the old machine i've Sanyo Denki 500W DC80 Model 850T-0123EL7 , brushed motor .
Let me know what you think!
Ps- I've only to think to the z axis and than i can buy all of them.
- 3 x Leadshine ELM1 750W with brake
- 3 x Leadshine AC Servodrive EL6 750W
- 1 x Mesa 7I76EU(not from the same shop)
Moderators: piasdom
Time to create page: 0.108 seconds
