Mecanumeric MF2040 LI retrofit (Pantograph)
- jackj120
04 Sep 2025 19:50 - 04 Sep 2025 19:57 #334432
by jackj120
Replied by jackj120 on topic Mecanumeric MF2040 LI retrofit (Pantograph)
It's been a while since the last post . So i've mounted all the machine and today i've done the first work with it , but there is a problem it's mirrored (like the second photo) . So searching online and talking with chatgpt i saw that someone change the sign of the step_scale and so I did , but than i've problem with the limits . And i have to change them and adapt but i did not figured out yet how to do that properly , so any advice for that is well accepted. Other thing, i've to leave the normal axis gui and change that with one mine personalized because i need custom buttons (and it's more cool) .Can someone give me some advice?
Last edit: 04 Sep 2025 19:57 by jackj120.
- Thank you received: 7478
05 Sep 2025 00:39 #334455
Replied by tommylight on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Probably would need also changing the - sign for home_search_velocity and maybe home_latch_velocity for that axis/joint.
- jackj120
05 Sep 2025 07:23 #334474
by jackj120
Ok but, when i'm done with the homing , the machine have a problem with the limits. It's convinced that it have the two meters going to the limit homing switch but after the homing it would have to do go to the others side for two meters. Maybe today i figure out how to do that.
Moderators: piasdom
Time to create page: 1.111 seconds
