Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
- ZXT
10 Jul 2025 20:56 - 10 Jul 2025 21:42 #331667
by ZXT
Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie. was created by ZXT
Hello! First of all I’m sorry if this is placed in the wrong category. I’m pretty much new to Linux and LinuxCNC and been busy building a CNC mill but I’ve stumbled up on a lot of problems.
My first thought was to get some help by using AI (Copilot) to configure Linux CNC but it doesn’t work that well because info online is limited on 2.9.4 so the AI is trying to use solutions that’s outdated for previous versions of LinuxCNC.
The progress I’ve made so far is to configure and flash firmware to 7i95t with MesaCT and edit hall and ini files to run QTdragonHD and get the stepper motors to move but then I wanted do add 3 MPGs to jog each axis.
Well that didn’t work that good.. these are the things I hope to accomplish one day:
1. X-Y-Z MPGs with incremental and continuous movement.
2. E-stop circuit (input) with reset.
3. Add limit switches
4.Closed loop feedback by using glass DRO scales.
5.Spindle control 0-10v VFD or just relay control.
6. Inputs/physical buttons: cycle start, cycle stop, 3 position resolution rotary switch for MPGs,
7. Joystick (switches) to feed X and Y. (Like a power feed on a manual machine) with a potentiometer to adjust feed rate)
8. Output for fogbuster/flood coolant.
9. Output for Compressed air nozzle.
The list is long,
I don’t know where to go from here..
Errors I’ve got earlier is missing motion.so and other modules, I’ll post the basic ini and hal files to.
The list is long,
Last edit: 10 Jul 2025 21:42 by ZXT.
- Thank you received: 5335
10 Jul 2025 21:20 #331669
Replied by PCW on topic Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
for # 1 and #7 I would use the built-in MPG encoders.
I don't know what if any MPG setup options MesaCT has
(it should be able to setup limit/home switches and spindle controls)
No sure if any configuration utility knows the 7I95/7I95T
MPG count pins but they would be:
hm2_7i95.0.inmux.00.enc0-count
hm2_7i95.0.inmux.00.enc1-count
hm2_7i95.0.inmux.00.enc2-count
hm2_7i95.0.inmux.00.enc3-count
- ZXT
10 Jul 2025 21:29 #331670
by ZXT
Replied by ZXT on topic Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
This is the basic function, it’s possible to jog the machine with buttons in QTdragon
- ZXT
10 Jul 2025 21:38 - 10 Jul 2025 21:45 #331671
by ZXT
At one point I got these pins to register counts in Halmeter:
But ended up getting errors for missing module: Motion.so so tried clean install and wiped everything,
MesaCT is a useful tool but haven’t found any encoder settings other than motor encoder setting,
I’ve tried to flash different firmwares also because some firmwares doesn’t have all settings available for encoder and spindle in MesaCT,
At the moment I’m running 7i95t_1pwmd
I think 7i95t is only supported by MesaCT, tried to use pncconfig because I’ve seen posts about people using the 7i95 config and edit I/O mapping and such, but couldn’t find the 7i95 either.
Last edit: 10 Jul 2025 21:45 by ZXT.
10 Jul 2025 21:46 #331672
Yes, you will probably need to setup the MPGs manually
MesaCT should allow you to setup home/limit switches,
your coolant outputs and the Spindle control outputs
(not sure about the spindle PWM)
So I would setup the limit/home switches and various outputs
next ( since support for these is built into MesaCT )
- ZXT
10 Jul 2025 21:55 - 10 Jul 2025 22:00 #331674
by ZXT
Yes, start with all the settings that’s possible to get in MesaCT,
Spindle relay would probably be good enough for now because the mill has a gearbox and 2 speed motor but that’s possible to fix easily outside of software if necessary,
For some reason there’s a lot of modules that’s missing and causing faults, I don’t know maybe the new changes to 2.9.4 don’t need them and the AI think they should be there and write HAL with functions that’s not supported any longer
Last edit: 10 Jul 2025 22:00 by ZXT.
10 Jul 2025 23:59 #331683
I would use pncconf (the new one in the link) or MesaCT
and avoid AI as it's really just a time sink here.
I have never seen a missing module in 2.9.4
( There is no motion.so in LinuxCNC so don't take bad advice from AI )
- ZXT
13 Jul 2025 19:25 - 13 Jul 2025 19:32 #331780
by ZXT
I’ve been trying to get some stuff working and it’s starting to get there,
Added some stuff and mpgs are reading and moving X, Y, Z but it immediately throws an error of positioning error, tired to adjust max acceleration for all axis, and also asked AI to help me make filtering/limiting, worked a little bit, but it went slow and unresponsive,
picture explains more of what happened
sorry for all comments in the files being Swedish.
Last edit: 13 Jul 2025 19:32 by ZXT.
13 Jul 2025 20:08 #331782
These (marked) values will cause a following error if you jog axis:
[AXIS_X]
MIN_LIMIT = 0
MAX_LIMIT = 200
MAX_VELOCITY = 40
MAX_ACCELERATION = 200
[JOINT_0]
AXIS = X
TAB = 0
CARD = 0
MIN_LIMIT = 0
MAX_LIMIT = 200
MAX_VELOCITY = 50
TYPE = LINEAR
SCALE = 320
STEP_INVERT = False
DIR_INVERT = False
STEPGEN_MAX_VEL = 50.00
This is because there is no hardware headroom at 50 mm/s
so if s velocity of 50mm/s is commanded, the hardware may not be
able to keep up. This may be a MesaCT bug, the stepgen maxvel
value need to be about 20% larger than the axis and joint maxvel
values. In this case I would (for all joints) change the joint
maxvel to 40mm/s
Another possible cause of following errors is the close setting of the DPLL
sample time, I would change this from -50 usec to -200 usec
I would also toss all the jog filtering as it's just likely masking a setup issue
[AXIS_X]
MIN_LIMIT = 0
MAX_LIMIT = 200
MAX_VELOCITY = 40
[JOINT_0]
AXIS = X
TAB = 0
CARD = 0
MIN_LIMIT = 0
MAX_LIMIT = 200
MAX_VELOCITY = 50
TYPE = LINEAR
SCALE = 320
STEP_INVERT = False
DIR_INVERT = False
maxvel to 40mm/s
- Benb
- Thank you received: 61
14 Jul 2025 01:29 #331799
by Benb
Replied by Benb on topic Configuring LinuxCNC 2.9.4 Mesa 7i95t Newbie.
Try this mpg configuration, you need one toggle switch to choose incremental or continuous jog mode, one 3 position selector switch and one MPG encoder. This configuration will work for hardwired or ui based switches. I am showing the configuration for hardwired system.but if you need to use soft switches replace hm2.7xx... with exposed ui switch adresses. If you experience jog acceleration issues just play with jog acceleration value right now it's set for 1.0.
# 3 axis hal mpg configuration
# This section will set the jog mode using a hardwired toggle switch
# switch open incremental mode switch closed continuous mode
net set-mode hm2_7ixx.your input-address-of-toggle-switch
net set-mode joint.0.jog-vel-mode
net set-mode joint.1.jog-vel-mode
net set-mode joint.2.jog-vel-mode
net set-mode axis.x.jog-vel-mode
net set-mode axis.y.jog-vel-mode
net set-mode axis.z.jog-vel-mode
# Set jog scale (as per your configuation 0.1)
net mpg-scale 0.1
net mpg-scale joint.0.jog-scale axis.x.jog-scale
net mpg-scale joint.1.jog-scale axis.y.jog-scale
net mpg-scale joint.2.jog-scale axis.z.jog-scale
# Set jog acceleration (value between 0 and 1)
net jog-accel 1.0
net jog-accel joint.0.jog-accel-fraction axis.x.jog-accel-fraction
net jog-accel joint.1.jog-accel-fraction axis.y.jog-accel-fraction
net jog-accel joint.2.jog-accel-fraction axis.z.jog-accel-fraction
# Joint selection (enable only one at a time)
net mpg-select-x joint.0.jog-enable axis.x.jog-enable <= hm2_7ixx.your input x address of selector switch
net mpg-select-y joint.1.jog-enable axis.y.jog-enable <= hm2_7ixx.your input y address of selector switch
net mpg-select-z joint.2.jog-enable axis.z.jog-enable <= hm2_7ixx.your input z address of selector switch
# Connect encoder counts to all joints (only enabled one will move)
net mpg-counts hm2_7ixx.your mpg encoder address
net mpg=counts joint.0.jog-counts axis.x.jog-counts
net mpg-counts joint.1.jog-counts axis.y.jog-counts
net mpg-counts joint.2.jog-counts axis.z.jog-counts
net mpg-scale 0.1
net jog-accel 1.0
Moderators: piasdom
Time to create page: 0.142 seconds
