ECMO VMC100 Retrofit with Carousel/Toolchanger
26 Jul 2025 12:06 - 26 Jul 2025 12:07 #332363 by hitchhiker
Hi guys!
I get a VMC-100 as gift from a school.
I owm a F1P which i retrofit to LINUXCNC years ago. works perfect.
Same Machine as the VMC-100 but with manual Toolchange.
Now the VMC-100 has a carousel as Toolchanger.
This carousel have 4 proximity switch to operate the Toolchanger.
Sensor1 is a sensor to reference tool 1.
Sensor2 counts a hole in a parallel gear. is it counts 2 times the next toolslot is reached.
Sensor3 tells that the tool is engaged.
Sensor4 tells that the tool is disengaged and the mainspindle can rotate the carousel.
Main issue for me is that the carousel works above the Z reference sensor.
At Z reference positon the Carousel begins to disengage the tool and when sensor 4 is reached the carousel can rotate.
Does someone ever retrofit this in Linuxcnc and can share his experience?
I searched a bit arround but found only some videos with MACH3 and some dead threads.
I will use the orignial maindrive which has a encoder on it at the beginning.
the maindrive works with step/dir signals.
On my f1p was the same maindrive which i use to tap threads.. spindle orient is used for this but iswitch to a 1kw servo.
this time i will use everything orignial because i have 3 orignial stepperdrivers for the 5 phase steppers. later i would change to nema23 2 phase.
Main focus is to bring everything back to live without changing to different steppermotors or maindrive.
The maindrive is working and the encoder counts.
Steppers working.
all proximity sensors are working.
thanks for any help :)
the pictures are taken from youtube
Last edit: 26 Jul 2025 12:07 by hitchhiker.
27 Jul 2025 15:57 #332417 by andypugh
Replied by andypugh on topic ECMO VMC100 Retrofit with Carousel/Toolchanger
You can temporarily move the Z max limit using the inihal pins in a toolchange macro.
linuxcnc.org/docs/html/man/man1/milltask.1.html
The "carousel" HAL component can probably be used to control the tool carousel, in conjunction with a G-code subroutine to move the axes and check the sensors.
The sample config sim/axis/vismach/vmc_toolchange should be a good starting point.
27 Jul 2025 16:25 #332424 by hitchhiker
Replied by hitchhiker on topic ECMO VMC100 Retrofit with Carousel/Toolchanger
issue is the toolchanger is turned by the spindle.. :( with spindle orient it works but its crap..
need spindle in velocity as spindle and in position mode for referencing the toolchanger and make toolchange...
27 Jul 2025 16:29 #332426 by andypugh
Are you using the "orient" component? I _think_ that should allow you to set it to orient angles > 360 degrees.
27 Jul 2025 17:02 - 10 Sep 2025 20:07 #332431 by hitchhiker
Emco use encoder from spindle for ramp up and down speed between toolslots and calculate the way in theorie.. then the other sensors looking for the real position
Last edit: 10 Sep 2025 20:07 by hitchhiker.
27 Jul 2025 17:14 - 10 Sep 2025 20:05 #332435 by hitchhiker
Failures in spindle hal :(
Last edit: 10 Sep 2025 20:05 by hitchhiker. Reason: Dont want people bring to bad hals
27 Jul 2025 17:24 #332436 by andypugh
m19 r360 p1
m5
m19 r360 p1
m5
This isn't the answer, nor even necessarily part of the answer, but M19 R720 P1 should work.
You couls consider using the carousel component and leave the spindle in velocity mode. Simoly use the spindle as a carousel motor and turn it on to change tools and off when the right tool is in position. (Use the slot sensor as the the strobe signal that "carousel" supports)
27 Jul 2025 17:36 #332438 by hitchhiker
m19 r720 p1 doenst work. its limited value 0-360 this was the first i try.. i had another idea...
using 2 relays.. switching between 2 step/dir signals from the mesa.
when toolchange is called..
m5
g4 (some value)
switch the relay to get position mode from a stepgen
make the toolchange
toolhange done.. switch the relay back to the stepgen for velocity mode
this is the hardware solution... needs 3 extra pins... 1 for relays 2 for extra step/dir
but is this not possible without relays and inside the hal? thanks
27 Jul 2025 19:03 - 27 Jul 2025 19:05 #332440 by hitchhiker
could you show me a exmple? i dont understand how i can connect the carousel.comp with the spindle... i go in basement and checked again. m19r720p1 doesnt work... :(
i understand that this compnent is very useful but i dont understand how i can link it up with the spindle to turn the carousel.
Last edit: 27 Jul 2025 19:05 by hitchhiker.
27 Jul 2025 21:50 - 10 Sep 2025 20:08 #332447 by hitchhiker
With carousel it should be possible but its a hard way
Last edit: 10 Sep 2025 20:08 by hitchhiker.
Moderators: piasdom
Time to create page: 0.422 seconds
