ECMO VMC100 Retrofit with Carousel/Toolchanger
12 Sep 2025 15:25 #334886 by hitchhiker
Replied by hitchhiker on topic ECMO VMC100 Retrofit with Carousel/Toolchanger
Hi! And.. success!!!!!!
I found some issues in my ngc!
Later i make a video and upload! Then i show how to get a working toolchanger with the carousel.comp!
I made 3 failures...
Debounce-Modul wrong CAP!
Timing placing in the ngc
Order of handle stuff in the ngc
I collect later everything and show it.
Thanks to andypugh to show the right way.
Its not so fast like original Emco but its everytime done a correct Toolchange!
14 Sep 2025 10:51 #334971 by hitchhiker
The following user(s) said Thank You: andypugh, tommylight, jschulze, Daneel, Unlogic
20 Sep 2025 03:12 #335206 by CarbonNater
Replied by CarbonNater on topic ECMO VMC100 Retrofit with Carousel/Toolchanger
This is awesome! I actually just today started wiring up the retrofit of my EMCO Concept Mill 155. Newbie to linuxcnc, so it’s been going slow so far. Would you be open to sharing your setup files? I’ve got the same tool changer, would love to see your code for that.
21 Sep 2025 07:44 #335236 by hitchhiker
Hi i dont know if you have the exact same toolchanger. Can you check how many sensors you have on the toolchanger?
In the past i saw same system with 4 sensors.
From where you are?
29 Sep 2025 03:33 #335532 by CarbonNater
I’ll have to peak in and look at how many sensors it has, everything I’ve seen it looks nearly identical. I’m in the states, in Texas.
10 Oct 2025 19:35 #336215 by CarbonNater
Looks like mine has two sensors for the tool turret and the z limit switch.
Moderators: piasdom
Time to create page: 0.182 seconds
