- Thank you received: 75
A search for "M6 x .75 grease fitting adapter" resulted in a bunch of hits on Scamazon for 4mm tube compression fittings (both elbows and straights).Good info.
What are the compression fittings you are using on the trucks? That is usually the more difficult part to source due to the odd pitch of 0.75 on some LM blocks.
For a lathe I would need 10 remote ports if direct fed like on your setup. That might be okay.
Equal length tubing may be a solution to avoid metering units if running it off a manifold. Any experience with that?
