- Thank you received: 8
I can not confirm, but i read a lot of Creality CR-30 3D printers have a failed motor shaft from factory, not reduced but long, and i do have a CR-30 that is still OK. The belt on those is 10mm wide and tight like a drum, literally.
Can anyone confirm that this is a recognized risk with this arrangement ?
With a reduced shaft ?
