retrofitting a Proxon for coin die milling
- mclien
14 Apr 2026 15:14 #345542
by mclien
retrofitting a Proxon for coin die milling was created by mclien
As I'm planning to do live coin minting at some events I attend, I will retrofit a proxon milling thing to make my own coin dies.
Model is this one:
forum.drucktipps3d.de/file-download/12960/
I'm in contact with a nice austrian guy, who has done that before LinuxCNC exists (uses some old DOS software via par port). So the mechanical part is quite proven.
Plan is as follows:
- replace all threads with ballscrews
- a mesa 7i96s (have that from a dead project)
- stepper motor and microstepper driver (from yet another dead project)
- maybe place a 1:6 gear between stepper and ballscrew (this is actually trick from the austrian guy) for higher detail
My main question is about the milling spindle. As I will mill little amounts of material, I was aiming for some small spindle (partially for lower weight to have faster and more precise movements). On the other hand it should have quite high rpm and very good concentricity.
So far I was thinking a AMB 530 FME. At least I couldn't find a lighter one that would serve the purpose.
Please let me know if my plan might generate a working machine or if I have a major f-put in my plan.
Model is this one:
Plan is as follows:
- Thank you received: 7492
14 Apr 2026 19:05 #345549
Replied by tommylight on topic retrofitting a Proxon for coin die milling
Al that seems fine, but, is the machine stiff enough so it justifies ballscrews?
Is that the really small mill with metal ways? That should be OK.
- mclien
14 Apr 2026 19:33 #345550
by mclien
Replied by mclien on topic retrofitting a Proxon for coin die milling
ballscrews ar primary because the original threads in brass nuts have quite some deadway. But yes, it is all metal and the swallow tail rails are even adjustable. Plus it is the same model the other guy was using for years.
Only difference so far: He used a setup, where the motor was separated from the machine with a belt transmission and the z-axe was only moving the milling bit.
Also: I thought I might use one of my older PC standing around, but the latency test told me other wise (150ms and above).
Next try raspi4...
Next try raspi4...
14 Apr 2026 19:37 #345551
Do the old PC's have a parallel port on the back side, the violet/pink colored 25 pin one?
- mclien
14 Apr 2026 20:12 #345552
by mclien
No not that old. But maybe I lack some general understanding.
1. my raspi4 gets an base thread may jitter of 126 ms (126000 ns), which is supposed to be not usable for linuxCNC ( so why is there an image for that?)
2. or is the mesacard exactly there to address that problem with it's FPGA?
Sorry for the somewhat below rookie-level questions
14 Apr 2026 20:22 #345553
I do not use RPI but 126000ns is 126us or 0.126ms, so should still be OK for mesa boards.
- Thank you received: 4153
14 Apr 2026 22:57 #345560
Replied by rodw on topic retrofitting a Proxon for coin die milling
Some people run the pi4b with a slower servo thread eg 2 ms or 1.5 Ms with mesa cards
run:
latency-histogram --nobase --nobase 1000 --show
and share the screenshot here. the 4b is marginally OK but 126us is fine for a Mesa card at 1 ms servo thread.
run:
- NWE
- Thank you received: 84
15 Apr 2026 01:57 #345565
by NWE
Replied by NWE on topic retrofitting a Proxon for coin die milling
Just so you know, LinuxCNC has backlash compensation parameters. That said, I'm not real sure milling dies would go well with backlash. I used to have a diy CNC router with cheap ACME screws, running LinuxCNC + parport + microsteppers. I did more drilling than routering with it, drilling the thru-holes in home-brew PCBs. On that machine, backlash compensation was the ticket.ballscrews ar primary because the original threads in brass nuts have quite some deadway.
- mclien
17 Apr 2026 19:23 #345651
by mclien
Here are the 2 screenshots of the Pi. One whithout anything but the Desktop running, one with glxgears running (window resized to about the double).
17 Apr 2026 20:09 #345655
Replied by andypugh on topic retrofitting a Proxon for coin die milling
Pi5 might work better. But given that you have a 7i96 the Pi4 should work fine with the latency shown. (Just don't watch YouTube while milling)
Moderators: piasdom
Time to create page: 0.264 seconds
