- Hardware & Machines
- CNC Machines
- Milling Machines
- Mikron WF 40 P Retrofit - Gearbox Logic and Document Hunt (WF 40 C vs P)
- Dan.Aguedo
12 Jun 2026 20:20 #347046
by Dan.Aguedo
Mikron WF 40 P Retrofit - Gearbox Logic and Document Hunt (WF 40 C vs P) was created by Dan.Aguedo
Greetings gentlemen,
Our team at EreborCore (based in Peru) recently acquired a legendary piece of Swiss iron: a Mikron WF 40 P from the 1990s. Mechanically, the machine is in pristine condition (beautiful Meehanite cast iron, silent ball screws), but we are doing a complete electronic retrofit to bring it into the 21st century.
First of all, I want to give a massive shoutout to user @Vojta333. We found his Google Sheet detailing the 8-bit logic for the 21-speed gearbox on the WF 40 C, and it is a masterpiece of reverse engineering. We already have the S and M bitcodes (J2/2 to J2/9 pinout) ready to be integrated into our controller's custom Ladder/PLC logic.
However, we have encountered a historical "ghost" regarding the "P" variant, and we would highly appreciate your collective expertise on two specific matters:
1. The Mystery of the "P": Does anyone have the official electrical or mechanical manuals specifically for the WF 40 P? While the "C" (Contouring) version is widely documented, official schematics for the "P" version seem extremely hard to find. We would love to know the exact technical differences.
2. Gearbox Actuator Design: On our WF 40 P, the shifting mechanism on the side of the head looks like a small, enclosed manifold/box. In some older WF 40 C videos, the mechanism looks slightly more exposed. Does anyone know if Mikron switched to a compact hydraulic shifting manifold for the later "P" series, or is it just a cosmetic/protective cover for the same relay-driven mechanical array?
We are completely modernizing the system: we are getting rid of the old analog electronics and installing a brand new, fully digital SZGH controller along with modern AC servos and drives.
We are extremely excited about this project and we intend to fully document and share our retrofit journey here with the community. Any advice on the documentation hunt or the gearbox manifold would be gold to us!
Best regards,
Daniel
EreborCore Team
Best regards,
Daniel
EreborCore Team
03 Jul 2026 20:35 #347493
Replied by andypugh on topic Mikron WF 40 P Retrofit - Gearbox Logic and Document Hunt (WF 40 C vs P)
This sounds like a lot of fun, unfortunately all I can do is offer good wishes with the project. But keep us informed, and maybe there will be other questions that are easier to answer.
- Thank you received: 7492
03 Jul 2026 20:51 #347496
Replied by tommylight on topic Mikron WF 40 P Retrofit - Gearbox Logic and Document Hunt (WF 40 C vs P)
Sorry, been changing PC's and laptops a lot lately, had this set to reply and lost track.
Not much i can help with, but, since you are modernizing everything, you could do without schematics, either way it will require a bit of "hunting for signals" to figure out the remaining wiring, probably the relay boards for interlocks and/or tool changer, the rest is being replaced.
Here is my lathe and a bit of info on how i go about when no schematics is available:
forum.linuxcnc.org/show-your-stuff/32784...-15-retrofit?start=0
And a Hurco BMC-20P mill that i had only a single page of schematics for it:
forum.linuxcnc.org/30-cnc-machines/33529-hurco-bmc-20p-retrofit
Moderators: piasdom
- CNC Machines
- Milling Machines
Time to create page: 0.214 seconds
