- Hardware & Machines
- CNC Machines
- Milling Machines
- Bearing replacement advice for PM-25MV mill (spindle and pulley shaft)
- Ismacr63
- Thank you received: 11
13 Jul 2026 15:23 #347749
by Ismacr63
Bearing replacement advice for PM-25MV mill (spindle and pulley shaft) was created by Ismacr63
I'm about to replace the bearings in my PM-25MV style mill. I've got a 1.8kW AC servo motor on the spindle that runs up to 4500 rpm.
Two questions:
For the bearings on the pulley shaft (the intermediate shaft that drives the spindle belt), should I go with C3 clearance or standard clearance?
What tapered roller bearings would you recommend for the spindle itself?
Any advice from people who've already done this would be great. Thanks!
Two questions:
- Thank you received: 4659
01 Aug 2026 06:57 #348337
Replied by andypugh on topic Bearing replacement advice for PM-25MV mill (spindle and pulley shaft)
You only need C3 if the bearing is an interference fit in the housing and on the shaft.
What are the original bearings? If they are C3 it will say on them.
- Ismacr63
01 Aug 2026 07:07 #348338
by Ismacr63
Replied by Ismacr63 on topic Bearing replacement advice for PM-25MV mill (spindle and pulley shaft)
The original bearings are 6209 2RS and 6009 2RS; they don't have "C3" stamped on them, so they are likely CN (standard clearance). They are press-fitted without any additional clamping.
Moderators: piasdom
- CNC Machines
- Milling Machines
Time to create page: 0.412 seconds
