- Thank you received: 5
I can spend that much but I feel like I'm already splurging with this card. I also feel that the NDR-240-48 might be tool little current. Just curious but why should I swap to a separate power supply for the 7i96.I always run 48 volts and sometimes as high as 90 volts but on a small machine I might consider 36 volts depending on manufacturers recommendations. 24 volts leaves too much available torque on the table.
I would prefer you to use seperate power supplies with the 7i96
Meanwell MDR-10-5 for logic (5v)
Meanwell MDR-60-24 for field power (24v) MDR-40-24 is Ok too.
Meanwell NDR-240-48 (48 volts) for motors but a LRS-350-48 (7 amps) might be cheaper and is a popular choice.
I will probably get that device then.Given the number of issues I've seen where people have tried to use 5v plugpacks or phone chargers for mesa cards, the extra $10 is a small price to pay for reliability.
I'm using three drivesI can't see where you mentioned how many drives you are using.
Is it really that significant? Using a 48V PSU vs a 24V psu. Unrelated, but I feel like you may be sponsored by meanwell.If you follow my advice and run a higher voltage power supply for motors, you need a seperate 24 volt power supply for field power.
