Syil stepper drivers
- tactustech
I'm having trouble setting up the stepper drivers on my machine as the only thing it came with was a mach3 config file and minimal information on what is needed to drive the proprietary stepper drives (2 us minimum pulse width is all they give).
Here's what I have done so far:
I have been playing with the timing and can't get a combination that causes any sort of movement. My guesses were based off a config file for a previous model by the same company.
I know the parallel port is set up and sending/receiving signals by BigJohn's tester
Any suggestions would be greatly appreciated!
- BigJohnT
- Thank you received: 1176
- tactustech
- BigJohnT
- BigJohnT
YOU ARE MY FIRST guinea pig so look carefully at each page.
I have verified that the Stepconf Wizard will indeed open the file and build but nothing else.
- tactustech
Thanks again,
Rob
- BigJohnT
- cncbasher
- Thank you received: 288
If you zip up the macktree xml file and attach it I can convert it to a Stepconf Wizard file
John[/quote
what was the error John , i get an error also ?]
- BigJohnT
I just sent you the latest version.
- tactustech
I can play with the value using ptest.hal utility so that program seems to be able to write to the port. When I run LinuxCNC, I know the port is addressed correctly because I can see the signal initialize to high (as the .xml file says the machine wants), but when I try to jog the axis there's no waveform showing up on the pin that I'm probing. This seems to indicate there's something wrong with the pins within HAL. Is that correct? I've been trying to get through the integrator's manual and that looks like a good path for me to pursue. Are there any other areas I should look?
