- Thank you received: 486
Andy are you saying that homing and squaring dual axis is now doable !!andypugh wrote: I should have anticipated the need to reverse an axis, the motors point in different directions.
If you later decide you want home switches on both sides for self-squaring then just ask.
In the meantime, enjoy making stuff.
You will need to use gantrykins for that.are you saying that homing and squaring dual axis is now doable !!
Yep, forgot to mention that.Joints-axes and gentrivkins is likely to be better, but is quite a long way from standard.
