× Forum Header
The Express pci parport card address .What?
20 Aug 2016 09:39 #79130 by 819132306
I want to know the parport address .
I hope someone know this!
thank you
look at this :
qqqqqq@yyy:~$ lspci -v
00:00.0 Host bridge: Intel Corporation Mobile 4 Series Chipset Memory Controller Hub (rev 07)
Subsystem: Lenovo Device 20e0
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 20e4
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f2000000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 1800
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
00:02.1 Display controller: Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07)
Memory at f2400000 (64-bit, non-prefetchable) [size=1M]
00:03.0 Communication controller: Intel Corporation Mobile 4 Series Chipset MEI Controller (rev 07)
Subsystem: Lenovo Device 20e6
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f2826800 (64-bit, non-prefetchable)
00:03.2 IDE interface: Intel Corporation Mobile 4 Series Chipset PT IDER Controller (rev 07) (prog-if 85 [Master SecO PriO])
Subsystem: Lenovo Device 20ea
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 18
I/O ports at 1828
I/O ports at 180c
I/O ports at 1820
I/O ports at 1808
I/O ports at 1810
Kernel driver in use: ata_generic
00:03.3 Serial controller: Intel Corporation Mobile 4 Series Chipset AMT SOL Redirection (rev 07) (prog-if 02 [16550])
Subsystem: Lenovo Device 20ec
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 17
I/O ports at 1830
Memory at f2624000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: serial
00:19.0 Ethernet controller: Intel Corporation 82567LM Gigabit Network Connection (rev 03)
Subsystem: Lenovo Device 20ee
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at f2600000 (32-bit, non-prefetchable) [size=128K]
Memory at f2625000 (32-bit, non-prefetchable) [size=4K]
I/O ports at 1840
Kernel driver in use: e1000e
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 03) (prog-if 00 [UHCI])
Subsystem: Lenovo Device 20f0
Flags: bus master, medium devsel, latency 0, IRQ 20
I/O ports at 1860
Kernel driver in use: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 21
I/O ports at 1880
00:1a.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 22
I/O ports at 18a0
00:1a.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 03) (prog-if 20 [EHCI])
Subsystem: Lenovo Device 20f1
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f2826c00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 03)
Subsystem: Lenovo Device 20f2
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at f2620000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: c0000000-c01fffff
Prefetchable memory behind bridge: 00000000c0200000-00000000c03fffff
Kernel driver in use: pcieport
00:1c.1 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 2 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: f2500000-f25fffff
Prefetchable memory behind bridge: 00000000c0400000-00000000c05fffff
00:1c.3 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 4 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=0c, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f0000000-f1ffffff
Prefetchable memory behind bridge: 00000000f2900000-00000000f29fffff
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at 18c0
00:1d.1 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at 18e0
00:1d.2 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 03) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at 1c00
00:1d.7 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 03) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
Memory at f2827000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 93) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=0d, subordinate=0d, sec-latency=0
00:1f.0 ISA bridge: Intel Corporation ICH9M-E LPC Interface Controller (rev 03)
Subsystem: Lenovo Device 20f5
00:1f.2 SATA controller: Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Controller [AHCI mode] (rev 03) (prog-if 01 [AHCI 1.0])
Subsystem: Lenovo Device 20f8
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 16
I/O ports at 1c48
I/O ports at 183c
I/O ports at 1c40
I/O ports at 1838
I/O ports at 1c20
Memory at f2826000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 03)
Subsystem: Lenovo Device 20f9
Flags: medium devsel, IRQ 23
Memory at f2827400 (64-bit, non-prefetchable)
I/O ports at 1c60
Kernel driver in use: i801_smbus
03:00.0 Network controller: Intel Corporation PRO/Wireless 5100 AGN [Shiloh] Network Connection
Subsystem: Intel Corporation WiFi Link 5100 AGN
Memory at f2500000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
20 Aug 2016 09:55 #79136 by tommylight
Replied by tommylight on topic The Express pci parport card address .What?
Use "sudo lspci -v" and mind the letters !
There is no paraport in the attached.
20 Aug 2016 10:02 #79138 by 819132306
Replied by 819132306 on topic The Express pci parport card address .What?
thankyou
i use a express 34mm parport card
look at this:
20 Aug 2016 10:25 #79144 by tommylight
That is the actual PCI-E port, not something connected to that port.
Also, please use "sudo lspci -v" so it shows everything.
20 Aug 2016 11:15 #79145 by PCW
Also you need to be aware that some Express card parallel adapters are really
USB <--> Parallel devices so will not be listed by lspci and are not usable for motion
control with LinuxCNC
20 Aug 2016 14:30 #79159 by 819132306
Capabilities: [e0] Vendor Specific Information: Len=0a <?>
I/O ports at 1800
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 3
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable- Count=1/1 Maskable- 64bit+
I/O ports at 1828
I/O ports at 180c
I/O ports at 1820
I/O ports at 1808
I/O ports at 1810
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
I/O ports at 1830
Flags: fast devsel, IRQ 20
Memory at f2600000 (32-bit, non-prefetchable) [disabled] [size=128K]
Memory at f2625000 (32-bit, non-prefetchable) [disabled] [size=4K]
I/O ports at 1840 [disabled]
Capabilities: [c8] Power Management version 2
Capabilities: [e0] PCI Advanced Features
I/O ports at 1860
Capabilities: [50] PCI Advanced Features
I/O ports at 1880
I/O ports at 18a0
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Lenovo Device 20f3
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link
I/O ports at 18c0
I/O ports at 18e0
I/O ports at 1c00
Capabilities: [50] Subsystem: Lenovo Device 20f4
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
I/O ports at 1c48
I/O ports at 183c
I/O ports at 1c40
I/O ports at 1838
I/O ports at 1c20
Capabilities: [80] MSI: Enable- Count=1/16 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
I/O ports at 1c60
Capabilities: [e0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 00-1e-65-ff-ff-9b-0e-70
qqqqqq@yyy:~$
this is all,
thank you
20 Aug 2016 14:34 #79161 by 819132306
Whether the BIOS-related?
20 Aug 2016 14:39 #79162 by 819132306
Yes, I'm for this headache.
My computer is X200T.
BOIS version has no parallel port option
BOIS version needs to be upgraded.
Lspci-v can directly display all devices, including BOIS is not recognized?
My English is rubbish rely on translation software, do not know if there are any ambiguities
20 Aug 2016 15:17 #79167 by tommylight
That is a Lenovo X200 right???
You can not use that laptop to control an actual machine due to way to many power saving options that can not be disabled in BIOS.
I had several X220 and they are magnificent in any way except for actually controlling a machine.
You can use older T40/T41/T42/T43 models or X60 with a docking station (paraport is on the dock), and they are very usable, if you set the latency above 35000.
As for lenovo, install the sim version of linuxcnc so you can check and if needed correct the gcode before transferring it to the machine.
20 Aug 2016 17:23 #79181 by 819132306
yes, x200t,
BOIS version has no parallel port option.
do i update the bois,
this netbook latency 15000
Time to create page: 0.123 seconds
