Forum Header
gmoccappy and stepconf wizard's files
7 years 7 months ago #127905 by celalcnc
Stepconf wizard creates ini and hal file for only axis. I use parallel port for interfacing motor drivers. Can we rearrange stepconf wizard ini file for gmoccapy and hal file for parallel port?
Thanks in advance who reply this post.
7 years 7 months ago - 7 years 7 months ago #127908 by Leon82
You can pick GMOCCAPY from the step config wizard
Edit to add, on 2.8
In the ini all you have to do is replace the word axis with GMOCCAPY where it says display
Last edit: 7 years 7 months ago by Leon82.
7 years 7 months ago #127958 by pl7i92
yiu may now STEP into PRO USER and
TAKE Editor"gedit" and edit one LINE by HAND
DISPLAY = axis
DISPLAY = gmoccappy
IF there is a PYVCP panel plese unmark it with #
also the postgui HAL of the panel and you are up
The following user(s) said Thank You: celalcnc
Time to create page: 0.298 seconds
