Forum Header
Parport Base Address and Launch my mill app (using Virtual Box, no mill, etc)
7 years 7 months ago #129093 by Grotius
@Michael Chan,
If you want only to run simulation's you don't need a parport config at all.
You actually need a simulation configuration to test your machine output.
The axis config's has a simulation version (standard). This ini and hal config's can be used and can modified all over the linux sources.
It works with Gscreen, Gmocappy, etc. It even works with Ethercat (the fastest protocol). Because linuxcnc is written to be compatible.
Are you running a virtual box in windows? So yes, why?
The following user(s) said Thank You: NullStudent
7 years 7 months ago - 7 years 7 months ago #129096 by NullStudent
tbh, I'm just rather not deal with linux on my laptop, but should probably get in on my laptop, if this is the case. As for why, well I was planning on just messing around with the simulations, but wanted to try other things out. Then this happen, so my bad. also Oof.
Last edit: 7 years 7 months ago by NullStudent.
7 years 7 months ago - 7 years 7 months ago #129098 by Grotius
In window's you can do certain things, but not very much things, like command line command's like sudo.
Sudo mean's power. If you type : ping forum.linuxcnc.org
you get :
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max/stddev = 99.633/99.945/100.309/0.244 ms
If you type sudo before, you are in the endless loop.
So keep in mind. Once you start with linux, you will stay there if you are curious about linux.
Within 10 year's window's will not be used anymore. Who has a nokia phone today? Nokia and window's lost the battle.
Last edit: 7 years 7 months ago by Grotius.
7 years 7 months ago #129099 by Todd Zuercher
Stepconfig can create simulation configs as well. (on the first Stepconf window there is a check box for create simulation.)
7 years 7 months ago #129100 by Grotius
That config he can use. But i prefer that Micheal uses a linux installation instead of windows.
Once he get used to it. He thinks back to my advise.
Linux can couple cnc, vision, all kind's of code's let's say in python in the same program. So power to the max.
If you have window's you have to contact 5 party's to collect code and combine code. Very stupid future idea isnt it?
7 years 7 months ago #129141 by pl7i92
there are plenty of simulation mashines on the system
also all GUI systems without a mashine atatches
see my YT channel with all this done on a non Realtime
Thanks to Mr Sammel decesed in 2018 in Memory of ICHGucksLive
www.youtube.com/channel/UCGuJsIoXW-exBAwdn38dXow/videos
