Forum Header
Steppers stuttering
4 years 5 months ago #243713 by remon_v
Replied by remon_v on topic Steppers stuttering
uuuh please don't laugh... but I fix the problem, it was the belt tention
4 years 5 months ago #243718 by tommylight
The following user(s) said Thank You: remon_v
4 years 5 months ago #243719 by Todd Zuercher
Replied by Todd Zuercher on topic Steppers stuttering
It can be a frustrating experience trouble shooting something like this. But it still feels good to have the problem fixed even if the solution seems embarrassingly simple.
The following user(s) said Thank You: tommylight, Clive S, remon_v
4 years 5 months ago #243722 by remon_v
Yes it does feel good! And I learned a lot…
4 years 3 months ago #247001 by JackRay
Replied by JackRay on topic Steppers stuttering
Hello to all,
I have just acquired a GIGABIT motherboard with a PENTIUM 100 2.8G processor, 4GBRam to run the CNC 5axes TCP. But despite the many readings of the forum that I could do: change BASE PERIOD, SERVO_PERIOD, setp parport.0.reset-time 5000, impossible to make my machine work properly, it stutters.
On my other configuration ASUS motherboard + SAMPRON 2.0 Go, 2Go of RAM the operation is perfectly fulide .
Could you please direct me to test parameter changes or more compatible hardware to drive this machine.
Thank you for your help
4 years 3 months ago #247005 by tommylight
Replied by tommylight on topic Steppers stuttering
Does it sttuter only when jogging or when running gcode ?
Do you get latency warnings?
Did you measure the power supply voltage while motors are moving?
First thing, try a different keyboard.
And do not change the servo period, set it back to 1000000 ( 1 million), that messes everything if set to other values.
The following user(s) said Thank You: JackRay
Time to create page: 0.223 seconds
