Forum Header
Spindle setup
2 years 9 months ago #290392 by tommylight
Replied by tommylight on topic Spindle setup
That is not valid gcode for a mill, it lacks
M3 S24000
Or similar at the start of gcode.
2 years 9 months ago #290395 by frprim
Replied by frprim on topic Spindle setup
I will try this same code and insert M3 s24000 at the code start and post results.
Thank you very much for all the help.
2 years 9 months ago #290398 by tommylight
Sorry, was busy having a coffee with friends, so forgot to add that you also need M5 at the end of gcode to stop the spindle.
2 years 9 months ago #290443 by frprim
Thank you Tommy,
what you said did the trick and it works flawlessly.
One more thing if you can answer me. While in Stepconf, when I reach to page with Spindle setup, I choose 0Hz to enter PDM mode. There are few settings there like: Speed 1, Speed 2, PWM 1 and PWM 2. If I change PWM1 from 0.1 to 0.4 then in Axis UI when I type G0 Z10 for example, it does not travel 10mm thus I have to change PWM1 and PWM2 until I find exact ratio. Why is that?
Many thanks
2 years 9 months ago #290449 by tommylight
Hmmm ... that seems not right, changing spindle PWM should have no effect on Z axis motion at all, so how?
Do you have speed control for the spindle?
2 years 9 months ago #290453 by frprim
No, I do not have any speed control. My spindle is actually a hand held router that has markings for speed (1,2,3, ...) that I have to adjust manually depending on the material that is being cut.
Time to create page: 0.070 seconds
