Forum Header
Motor locks but will not move when testing
2 years 3 months ago #306196 by waukeenahBob
I have 5v going to the BOB via a usb cable... both power and relay lights are on
am supplying 60vdc to the driver... green light on and I see power at the driver
driver has green light on
2 years 3 months ago #306199 by tommylight
Finish StepConf, save, start the config and try to move the machine.
StepConf is a wizard, and very good at what it does, but it can not account for every hardware variant/version/setup out there.
Also, if you have drive enable wired, disconnect them till you get the machine moving, then you can wire and test enable.
2 years 3 months ago #306202 by waukeenahBob
Ok... saved and exited StepConf
Started config it saved
I hear the relay tripping on the BOB
Toggled E Stop and Power in UI
I see the DRO changing but still no movement on the stepper
2 years 3 months ago #306203 by tommylight
Upload here detailed pictures of the wiring and the hal and ini files.
2 years 3 months ago #306204 by waukeenahBob
Also completely disconnected enable wires as recommended
2 years 3 months ago #306208 by waukeenahBob
Thanks so much for the help!!!!
I cannot believe I am having this much of a problem... this will be the 3rd CNC system I have built... the first in linuxcnc but that shouldn't make this much of a difference...
I figure I have done something dumb or I have a defective piece of hardware.
Time to create page: 0.409 seconds
