PCI, PCI-e Mesa and EMC2
- schmidtmotorworks
- Thank you received: 6
07 Jul 2011 03:11 #11205
by schmidtmotorworks
PCI, PCI-e Mesa and EMC2 was created by schmidtmotorworks
Thanks for all the help form the experts here, this is all beginning to make sense.
When choosing a computer mother board to run with a Mesa 5I23 FPGA based PCI Anything I/O card, I see that mother boards may have some combination of PCI and PCI-e slots.
Looking at the Mesa site, it isn't clear to me if the 5I23 requires PCI, PCI-e or if either will be fine.
The reason I am concerned is if things go well with 3 axis, I will want to add a second 5i23 later to control two more axis (the machine has 5 axis of servos) and want to be sure that the board has enough of the correct type slots.
- Thank you received: 4966
07 Jul 2011 10:52 #11215
Replied by andypugh on topic Re:PCI, PCI-e Mesa and EMC2
5i23 needs a PCI slot.
If you know that you will need 5 axes later, you could look at the 7i48 6-axis servo interface in place of the 7i33 4-axis one.
You need to run EMC2 v 2.5+ to use the 7i48, however.
- BigJohnT
- Thank you received: 1176
07 Jul 2011 11:55 #11223
by BigJohnT
Replied by BigJohnT on topic Re:PCI, PCI-e Mesa and EMC2
I see the 7i48 uses multiplexing to communicate encoder info back to the mothership does that affect anything with speed? Or is it so fast that it don't matter?
- Thank you received: 5203
07 Jul 2011 13:29 - 07 Jul 2011 13:35 #11226
Replied by PCW on topic Re:PCI, PCI-e Mesa and EMC2
For most servos it will be so fast it doesn't matter > 1 MHz with filtering on
This is 6000 RPM with a 2500 line encoder (10000 counts/turn)
With filtering off count rate will be around 3 MHz max so 18,000 RPM with the same encoder
For high speed spindles (> 18000 RPM) you would need to chose a lower resolution encoder
Note that normally the encoder itself will be the limiting factor, very few count higher than 1 MHz or so.
Forgot to say: the 5I23 is PCI
Last edit: 07 Jul 2011 13:35 by PCW.
- BigJohnT
07 Jul 2011 18:22 #11233
by BigJohnT
Thanks Peter, that is some good info to know.
Time to create page: 0.062 seconds
